gman
May 13, 2022, 3:44pm
1
Recently updated from 2021.8 to 2022.5
For some reason, all my Light button components now look really faded.
The color when turning the light on used to be a really noticeable yellow.
Any ideas?
tom_l
May 13, 2022, 3:48pm
2
It wasn’t the latest version. It was quite a while ago that the light colour changed to represent either the colour temperature or colour (for RGB) of the light.
gman
May 13, 2022, 3:51pm
3
I see
Any way of changing that?
tom_l
May 13, 2022, 11:24pm
4
Not yet. There’s an issue open about it:
opened 03:00AM - 11 Sep 21 UTC
integration: light
### The problem
https://github.com/home-assistant/core/pull/55219
this PR fo… rces color temp lights to report RGB values to change the color of the icon, breaking the aesthetics of most themes and leaving it almost impossible to distinguish between lights that are on vs off at a glance. As lights that are off are white and lights that cool white are also the same white.
### What is version of Home Assistant Core has the issue?
core-2021.9.5
### What was the last working version of Home Assistant Core?
core-2021.8.8
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
_No response_
### Link to integration documentation on our website
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
Most themes, the off color of icons is white. So if lights are on cool white they are now also white and impossible to distinguish from off. And when on and warm white they have an orangy icon. These icons used to follow the current theme and only adjust based on brightness while maintaining the color of the theme.
![image](https://user-images.githubusercontent.com/31552122/132933819-40a3d96a-4ae1-46d2-bf7e-3547da8b0c5f.png)
here the Lamps are ON but cool white, the ceiling and closet are off. Previously they would have been the themes color for on, in this case yellow.
![image](https://user-images.githubusercontent.com/31552122/132933840-8581c628-a810-4029-b83c-02cf843a72de.png)
Top 3 are not color temp lights while the bottom 3 are, completely breaking the consistency of the theme and every other icon.
Different attributes when on vs off
![image](https://user-images.githubusercontent.com/31552122/132933891-9518c50c-8165-4110-9d55-78342357154e.png)
![image](https://user-images.githubusercontent.com/31552122/132933897-c33f8a00-a7e0-44dd-bc54-24834697a7ad.png)
Color temp bulbs are not RGB and the attribute shouldn't be forced onto the entities. This was a "bug" previously when lights were reporting incorrect supported features, https://github.com/home-assistant/core/issues/52661, and now it is baked in as an actual "feature".
