Light button that sends Json commands to an espeasy flashed sonoff
I am just migrating from domoticz to Home Assistant and have a small problem with a couple of flashed sonoff devices.
In Domoticz I could just specify a url to be called on a button push and thereby send json commands to the sonoffs.
In Home Assistant i thought, that a command line button would work, but i does not take the url as an on or off command.
for example
switch:
Can someone help to get this working?
I specifically want to use the json commands and not mqtt.
Thanks in advance.
I think u need a RESTful Command
Or an RESTful Switch
