Light: Philips Hue Bulb
Radio: Zigbee (Combe II / ZHA)
I don’t know what happens, but some of the light on my kitchen keep virtually running on (the light don’t actually turn on but the status keep reporting on in home assistant)
I turn off in home assistant, few sec after back on…
I couldn’t find a automation on node red which would do that but I have so much I might have missed something
somehow, the same lights that give me some problem is the one which are a bit greyed out (but still actionable)
btw it’s seems to be random, the light stay off now
in my log I don’t see much expect a few errors which I don’t think are related
21-12-05 10:28:22 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:62073 ssl:default [Connect call failed ('172.30.32.1', 62073)]
21-12-05 10:30:00 ERROR (MainThread) [supervisor.utils] Can't execute write_stdin while a task is in progress
21-12-05 10:30:21 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-12-05 10:31:13 WARNING (MainThread) [supervisor.addons.options] Option 'require_ssl' does not exist in the schema for Node-RED (a0d7b954_nodered)
21-12-05 10:32:40 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:0 is not WSMsgType.TEXT
21-12-05 10:32:40 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
21-12-05 10:32:46 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
21-12-05 10:32:46 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
21-12-05 10:32:46 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
21-12-05 10:33:41 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:0 is not WSMsgType.TEXT
21-12-05 10:33:41 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
21-12-05 10:33:49 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
21-12-05 10:33:49 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
21-12-05 10:33:49 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
21-12-05 10:40:00 ERROR (MainThread) [supervisor.utils] Can't execute write_stdin while a task is in progress
21-12-05 10:42:45 WARNING (MainThread) [supervisor.addons.options] Option 'require_ssl' does not exist in the schema for Node-RED (a0d7b954_nodered)
21-12-05 10:42:53 INFO (SyncWorker_7) [supervisor.docker.interface] Stopping addon_a0d7b954_ssh application
21-12-05 10:42:54 INFO (SyncWorker_7) [supervisor.docker.interface] Cleaning addon_a0d7b954_ssh application
21-12-05 10:56:41 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-12-05 10:56:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-12-05 10:56:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
21-12-05 10:56:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
21-12-05 10:56:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
21-12-05 10:56:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-12-05 10:56:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-12-05 10:56:41 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-12-05 10:56:41 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-12-05 10:56:42 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-12-05 10:56:42 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-12-05 10:56:42 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-12-05 11:00:18 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
21-12-05 11:00:18 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
21-12-05 11:00:18 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/w35l3y/hassio-addons repository
21-12-05 11:00:24 INFO (MainThread) [supervisor.store] Loading add-ons from store: 63 all - 0 new - 0 remove
21-12-05 11:00:24 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
