I’m trying to set up an automation that changes a light to a specified profile from light_profiles.csv. The profile names work really inconsistently. It seems like it always applies the brightness, but the XY values often don’t apply with no discernible pattern.
I can call the light.turn_on
service with xy_color
instead of profile
which works fine, so I don’t think the XY values are the problem. I’ve also seen a few threads mentioning issues with light profiles when the light is already on, but that makes no difference in my case.
I found this comment on a Github issue that describes my problem, but I didn’t get anywhere with the rest of the thread. Specifically, I tried downgrading from 2024.1.6 to 2023.12.4 and 2023.12.1, neither of which worked.
I am using nikshriv’s Cync Lights custom integration, and unfortunately I don’t have any other types of lights I can test with to see if it’s an issue with the integration or not.
Sample from my light_profiles.csv:
id,x,y,brightness
Lily,0.385,0.155,255
Roxie,0.489,0.239,255
Inconsistently working service call:
service: light.turn_on
metadata: {}
profile: Roxie
entity_id: light.table_lamp
Consistently working service call:
metadata: {}
xy_color: [0.489, 0.239]
I’m tearing my hair out over this, any help would be appreciated.
