Light settings for action in automation
I have only one scene setup for setting the brightness and color temperature for two of my floor lamps:
[code]scene:
  • name: Home Theater Intermission
    hidden: true
    entities:
    light.living_room_left:
    state: “on”
    brightness: 112
    transition: 5
    color_temp: 369
    light.living_room_right:
    state: “on”
    brightness: 112
    transition: 5
    color_temp: 369[/code]
And the scene is controlled by automation:
[code]automation:
  • alias: “Kodi paused/stop”
    • platform: state
      entity_id: media_player.kodi
      service: scene.turn_on
      entity_id: scene.home_theater_intermission
  • alias: “Kodi playing”
    • platform: state
      to: “playing”
      service: light.turn_off
      entity_id: group.living_room_lights[/code]
However, I do not want the scene to be shown in the HA frontend. I set the hidden property for scene, but it does not disappear even after a restart. Why is that?
And I’m not sure if I could set the transition time for the group when the state is in playing mode.
You can set the hidden state for the scene at the customize section, under the homeassistant: header
Something like this:
homeassistant:
  # here goes the location config...
  customize:
    - scene.Home_Theater_Intermission:
      hidden: true
Hope it helps.
I think I came across the Customizing the devices and services (no dash for every device, services, and scenes) section, but there are times when I forget.
I got used to configuring home automation from a file instead of a GUI.
Anyway, thanks for your help.
