Light Switches in UI Playing Up
Hi There,
I’m having an issue with using my light switches from the user interface. Toggling the switch off doesn’t seem to be sending the corresponding command, and I don’t get the confirmation popup. Togging on seems to work most of the time with the popup appearing.
Running the 87.1 on a Hass Pi. I have a mix of MQTT and Zwave lights with the same issue. The lights follow automations fine so I think it may be something in the interface.
Any suggestions?
