Lighting Ballast Power
I do apologize if this is not the correct sub forum for this inquiry. Thank you very much for taking a look at this question. Whomever you are, you are very kind to do so, and a stranger in North Carolina appreciates you for it.
I’ve purchased a FLS-PP lp wireless lighting ballast from Amazon. My goal is to use it to power an LED strip under my kitchen cabinets. The power specifications require 12/24 volt. I would like to replace the existing halogen lamp which is controlled with a switch on the wall with the FLS-PP. However, all I’m seeing online is people using 12/24 wall adapters with this ballast. A Link to the product is below.
https://www.amazon.com/gp/product/B00NMSQ4QQ/ref=oh_aui_detailpage_o00_s03?ie=UTF8&psc=1
Is there anything I can do to get this thing hooked up without getting a power adapter and running it to an outlet? Can I use the existing wiring under the cabinet?
Thank you again!!
