Hello! My setup was unchanged during year, but after last 3-4 updates of ESPHome I got very strange behavior - during switching light on/off or just by dimming light to some specific brightness, during brightness change lights starting to flickering (fast blinking) and after reaching selected brightness - issue is gone and brightness is constant.
The installation is a central dimmer to which several lamps (24V strips in the ceiling) in the apartment are connected. Setup has its own powerful power supply, assembly of output transistors and module PCA9685 for PWM and PCF8574 for switches inputs, both are connected to ESP32 via I2C. There were problems with this module once at the beginning and they were solved by lowering the I2C speed. Now I have already played with different settings and the effect has remained.
I have already checked the free output in the transistor assembly (without load) using an oscilloscope - the PWM signal changes beautifully when light changing the brightness, but at some point there are dips to 0V for a split second, as if the module receives incorrect data (have tried to just disconnect I2C - all setted frequencys are remaining). The power supply and the PWM module are OK - when 1 lamp “blinks”, the rest work as they should. So by now, it looks like some kind of bug after the update, but I have not yet found how to check it and sure - how to fix…
Part of configuration:
esp32:
board: esp32dev
framework:
type: arduino
i2c:
sda: 21
scl: 22
scan: true
frequency: 100kHz
pca9685:
- id: pwm_i2c_hub1
frequency: 160
pcf8574:
- id: io_i2c_hub1
address: 0x20
pcf8575: true
output:
- platform: gpio
pin:
pcf8574: io_i2c_hub1
number: 0
mode: OUTPUT
inverted: true
- platform: pca9685
pca9685_id: pwm_i2c_hub1
channel: 0
light:
# PWM lights
- platform: monochromatic
output: pwm_1
name: "Dimmable light 1"
gamma_correct: 1.5
# Binary lights
- platform: binary
output: relay_1
name: "Binary light 1"
