Lights have spontaneously turned on
Hello all,
What could be the cause of the following problem. The bedroom lights and also the living room lights have spontaneously turned on several times at 4:16 am.
The logbook shows the message: room lighting changed to day triggered by service Input select: Select.
I haven’t set a trigger anywhere for this to happen. How could I find out what is causing this?
Thanks,
Peter
The input select service is not meant for turning on lights. Could it be you accidentally used a wrong entity in a input select service call? I recently had to change my Harmony integration to use select, maybe you did something similar?
Sorry for the late response. Was on holiday. I solved the problem on another way.
Thankx,
Peter
