I have a script with a sequence that makes lamps chase through colors. At the end the lamps go back to warm white. In the dashboard the lamps are regularly updating their color state visually while the script is running, but at the end the dashboard tiles won’t show the warm white anymore. Which is confusing ofc.
It doesn’t matter if the sequence is running 1 time or 10 times in the script, the lamps are updating in the dashboard the whole time right until they go to warm white.
How can I get it to update to the warm white color in the dashboard?
This screenshot is taken minutes after the script was completed, so they were outputting warm white:
Script:
sequence:
- repeat:
count: 3
sequence:
- sequence:
- alias: Rood
action: light.turn_on
metadata: {}
rgb_color:
- 255
- 0
- 0
transition: 3
entity_id:
- light.papasan
- light.salontafel
- delay:
hours: 0
minutes: 0
seconds: 3
- alias: Groen
metadata: {}
rgb_color:
- 0
- 255
- 0
transition: 3
entity_id:
- light.papasan
- light.salontafel
- delay:
hours: 0
minutes: 0
seconds: 3
- alias: Blauw
metadata: {}
rgb_color:
- 0
- 0
- 255
transition: 3
entity_id:
- light.papasan
- light.salontafel
- delay:
hours: 0
minutes: 0
seconds: 3
- action: light.turn_on
metadata: {}
transition: 3
rgb_color:
- 255
- 175
- 100
entity_id:
- light.salontafel
- light.papasan
alias: K3 woonkamer
description: ""
