Lights turn, then almost immediately off
Hi, I wonder if anyone can help me as it’s driving me mad.
I have home assistant running on a pc, I initially set it up on ZHA, and had this issue, now after setting it up with MQTT the issue persists.
I have a moes 2 gang battery operated light switch, and initially I was using a sengled bulb, but switched to a hue bulb hoping that would solve it.
If I set an automation press the switch, it will turn the on, then almost immediately off, if I turn the light on again, it will then stay on.
I have deleted, added, paired, re-paired and the issue is still there.
I even reinstalled HA from scratch, went from a sonoff dongle, to a smlight and back again,
It only seems to be this switch, the other (different makes) work fine, is it a duff one or am I missing something in the setup/config?
Any assistance would be greatly appreciated
