HI all,
I’ve installed HA to test out it and play with my existing lightwaveRF kit.
I’ve setup the configuration.yaml as per the guide, but am getting the following errors:
Invalid config for [lightwave]: expected a dictionary for dictionary value @ data[‘lightwave’][‘lights’][‘R1D1’]. Got ‘name:Lamp Post Light’ expected a dictionary for dictionary value @ data[‘lightwave’][‘lights’][‘R2D3’]. Got ‘name:Side lamp’ expected a dictionary for dictionary value @ data[‘lightwave’][‘switches’][‘R1D1’]. Got ‘name:Raspberry Pis’ expected a dictionary for dictionary value @ data[‘lightwave’][‘switches’][‘R2D1’]. Got ‘name:TV’ expected a dictionary for dictionary value @ data[‘lightwave’][‘switches’][‘R2D2’]. Got ‘name:Right socket’. (See /home/homeassistant/.homeassistant/configuration.yaml, line 25). Please check the docs at Lightwave - Home Assistant
My configuration.yaml lightwaverf section:
lightwave:
host: 192.168.5.15
lights:
R1D1:
R2D3:
switches:
R1D1:
R2D1:
R2D2:
trv:
proxy_ip: 127.0.0.1 # Proxy address, do not change unless running on a different server
proxy_port: 7878 # Do not change, unless a port clash
trvs:
R2Dh: # The ID of the TRV.
serial: DE98FE
I’ve already installed lwproxy for the TRV and have it running as a service on the server.
Any assistance you could offer would be useful. The white space in the above is all spaces, with indents of 0,2,4 and 6 spaces.
Thanks in advance
Garreth
