LightwaveRF command line syntax
I am trying to create a switch in HA that controls my LightwaveRF hub directly.
I can send the following commands directly from my Rpi command line and it switches the lamp on and off.
echo -n ‘100,!R2D1F1’ >/dev/udp/192.168.1.212/9760
echo -n ‘100,!R2D1F0’ >/dev/udp/192.168.1.212/9760
I cannot find the right syntax using echo that works from within HA when I try to define it as a switch.
This is the setup
  • platform: command_line
    switches:
    light_living_room_unit:
    command_on: echo -n ‘100,!R2D1F1’ > /dev/udp/192.168.1.212/9760
    command_off: echo -n ‘100,!R2D1F0’ >/dev/udp/192.168.1.212/9760’
[The spacing is correct in the configuration file]
I have tried various combinations of single and double quotes with no success
I already have lots of switches working using command_line with curl with no problems
Can anyone help?
Hi Tommy,
Did you ever resolve this mate?
Cheers,
Richie
