I appreciate this will be something silly I have done but.
I have an automation that will turn the light on when there is movement, set a certain colour depending on the time of day, then turn off if there is no movement after 1 minute.
this works fine during the day, but the light will not switch off at night!
I have checked, there has been no moment detected.
any ideas please?
- alias: 'light off'
platform: state
entity_id: binary_sensor.landing_pir
to: 'off'
for:
minutes: 1
service: light.turn_off
entity_id: light.02150034807d3a7693fd
- alias: 'Landing Pir night'
platform: state
to: 'on'
condition:
- condition: time
after: '18:30:00'
before: '05:59:59'
service: light.turn_on
brightness: 100
rgb_color: [0, 0, 255]
entity_id:
- light.02150034807d3a7693fd
- alias: 'Landing Pir evening'
platform: state
to: 'on'
condition:
- condition: time
after: '18:00:00'
before: '18:29:59'
brightness: 150
rgb_color: [255, 255, 255]
entity_id:
- alias: 'Landing Pir day'
platform: state
to: 'on'
condition:
- condition: time
after: '06:00:00'
before: '17:59:59'
brightness: 150
entity_id:
is there a copy paste issue going on here? Your spacing seems all out of whack. Is this what it looks like inside your yaml file or was some of the formatting lost? I wouldn’t expect any of these automations to work with the format in this post.
Reading through your code, I suspect that what’s happening is this -
You’ve built too much intelligence into your smart home and the light is now sentient. With that, it has picked up an irrational fear of the dark and now won’t turn off at night, because it’s scared.
I rebooted this morning and all i have in the log is the following:
Update for sensor.met_office_wind_direction fails
9:01 PM components/metoffice/sensor.py (ERROR) - message first occured at 8:25 PM and shows up 2 times
Update for sensor.met_office_weather fails
Error doing job: Task exception was never retrieved
8:30 PM helpers/entity_platform.py (ERROR) - message first occured at 8:01 PM and shows up 2 times
Update for sensor.met_office_wind_gust fails
7:50 PM components/metoffice/sensor.py (ERROR)
The light is coming on, but will not turn off when it is in its night setting…
