I am having some trouble getting a Shelly vintage light to work in my configuration.yaml, i can get the device to switch nicely through home assistant -> interactions -> mqtt tile -> configure using a JSON payload of:
{"turn": "off"}
or
{"turn": "on"}
Currently, I have entered the code below into my configuration.yaml with little luck.
I cant see how the home assistant would know what JSON string to send to the device with the code below, I suspect I need to use payload_on:
or command_on
to send the JSON but I can’t find it in the doc’s
light:
- platform: mqtt
name: "Shelly sidelight"
schema: json
state_topic: "shellies/ShellyVintage-D0FE8B/light/0/status"
command_topic: "shellies/ShellyVintage-D0FE8B/light/0/set"
brightness: true
P.S am using the Shelly discovery script but it doesn’t show up the bulbs as I think there is a bug, so this is why I’m using yaml.
