Linear NGDZ00-4 Garage Door
Is it 4.11 or 4.10?
So on the discord someone pointed out that
HA 0.81.6 is still py_ozw = 0.4.10
BUT
there was a merge very recently bumping to 0.4.11 for HA 0.82
As /zwave/init.py requirement is 0.4.11
Got it. So currently 4.10. But expect to move to 4.11 very soon
Ok, in an attempt to get my thermostats working, I pulled a couple more files from the dev branch. Didnā€™t notice any changes locally but I donā€™t have time right now to remove/add my thermostats. Anyone interested in testing? Good news is it didnā€™t break anything. Pretty sure it will add V3 setpoints to zwave thermostats.
Maybe I am missing something. I just upgrade HA when the new release comes out. If my garage door breaks I look at the python_openzwave requirements. I never upgrade anything else. Am I missing something?
Using docker, itā€™s easier to uninstall and install from a local fork when a rebuild (or update is needed) - than build and change the requirements
Sorry, I pushed this commit to move to 0.4.11. I have been testing it and itā€™s been very stableā€¦
ah no worries - and youā€™re right so far so good :slight_smile:
Quick bash script to update openzwave for the virtual env folks:
(modify your paths as necessary and version number/flavor)
#!/bin/bash
# Update python_openzwave
if [ "$(id -u)" != "0" ]; then
echo "This script must be run with sudo. Use \"sudo ${0} ${*}\"" 1>&2
exit 1
fi
echo "Changing to user homeassistant"
sudo -H -u homeassistant /bin/bash <<EOF
echo "Activating virtual environment"
source /srv/homeassistant/homeassistant_venv/bin/activate
echo "Updating python_openzwave to latest version"
export LOCAL_OPENZWAVE=/home/homeassistant/open-zwave/
pip uninstall -y python_openzwave
pip install python_openzwave==0.4.11 --no-cache-dir --no-deps --install-option="--flavor=dev"
echo "Deactivating virtual environment"
deactivate
EOF
exit 0
Update script for HomeAssistant:
(modify your paths as necessary)
#!/bin/bash
# Update AIO installed HASS
exit 1
fi
echo "Updating Home Assistant to latest version"
pip3 install --upgrade homeassistant
deactivate
EOF
exit 0
Iā€™m happy to see you posted this for us venv folk.
Iā€™ve been having trouble parsing this huge thread even after following it for a couple weeks (This thread is closing in on 1000 posts, wow!). I thought this was all I needed to do to get open-zwave to the version I need, but Iā€™m guessing I still need to do initial steps because when I run it I get:
Command "/srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-gmrvukal/python-openzwave/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-mg2nofr1/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.6/python-openzwave --flavor=dev" failed with error code 1 in /tmp/pip-install-gmrvukal/python-openzwave/
Could you please point me at the right post to get this working?
i spoke to soon, didnā€™t check if the actual cover.garage_door was there :frowning: meh
not a dev by any means, but there are some things here that are confusing:
ā€œ0.4.0.x versions are for testers only. Donā€™t use it in a production environement !!!ā€
ā€œThe previous command install python_openzwave statitically linked to sources downloaded from https://github.com/OpenZWave/python-openzwave/tree/master/archives. You can change this using flavors. There is a bug in the package dependencies and flavors on some systems. You may need to install dependencies manualyā€
You seem to be missing setuptools, you can switch to your venv and pip install setuptools.
Also note the --flavor=dev is for a local version of open_zwave on your system like @pdobrien3ā€™s fork:
So I still attempting to get homeassistant/raspberrypi3-homeassistant to work with OZW dev and have made some progress but have run into a issue and was wondering if anyone has any ideas:
Current dockerfile:
FROM homeassistant/raspberrypi3-homeassistant:0.81.6
RUN set -e && \
    apk --update add build-dependencies build-base\
    rm -rf /var/lib/apt/lists/*
RUN pip3 uninstall -y python-openzwave && \
    pip3 install --no-cache-dir 'python_openzwave==0.4.11' --install-option="--flavor=ozwdev" \
    apk del build-dependencies
This is the build log:
Sending build context to Docker daemon  3.072kB
Step 1/3 : FROM homeassistant/raspberrypi3-homeassistant:0.81.6
 ---> 71261674d2fc
Step 2/3 : RUN set -e &&     apk --update add build-dependencies build-base    rm -rf /var/lib/apt/lists/*
 ---> Running in ceff493406cb
apk: unrecognized option: r
fetch http://dl-cdn.alpinelinux.org/alpine/v3.8/main/armhf/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/v3.8/community/armhf/APKINDEX.tar.gz
(1/13) Installing binutils (2.30-r5)
(2/13) Installing libmagic (5.32-r0)
(3/13) Installing file (5.32-r0)
(4/13) Installing isl (0.18-r0)
(5/13) Installing libgomp (6.4.0-r9)
(6/13) Installing libatomic (6.4.0-r9)
(7/13) Installing gcc (6.4.0-r9)
(8/13) Installing musl-dev (1.1.19-r10)
(9/13) Installing libc-dev (0.7.1-r0)
(10/13) Installing g++ (6.4.0-r9)
(11/13) Installing make (4.2.1-r2)
(12/13) Installing fortify-headers (0.9-r0)
(13/13) Installing build-base (0.5-r1)
Executing busybox-1.28.4-r1.trigger
OK: 325 MiB in 165 packages
Removing intermediate container ceff493406cb
 ---> e3967078a5ad
Step 3/3 : RUN pip3 uninstall -y python-openzwave &&     pip3 install --no-cache-dir 'python_openzwave==0.4.11' --install-option="--flavor=ozwdev"     apk del build-dependencies
 ---> Running in 87694178a49b
Uninstalling python-openzwave-0.4.10:
  Successfully uninstalled python-openzwave-0.4.10
You are using pip version 18.0, however version 18.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Collecting python_openzwave==0.4.11
  Downloading https://files.pythonhosted.org/packages/31/1a/6837bd4d3dd2bf5f8da5186b0b9b9ee865d21c4f31dc0fcc75deb651fb10/python_openzwave-0.4.11.zip (139kB)
Collecting apk
/usr/local/lib/python3.6/site-packages/pip/_internal/commands/install.py:206: UserWarning: Disabling all use of wheels due to the use of --build-options / --global-options / --install-options.
  cmdoptions.check_install_build_global(options)
  Could not find a version that satisfies the requirement apk (from versions: )
No matching distribution found for apk
The command '/bin/sh -c pip3 uninstall -y python-openzwave &&     pip3 install --no-cache-dir 'python_openzwave==0.4.11' --install-option="--flavor=ozwdev"     apk del build-dependencies' returned a non-zero code: 1
Does anyone know why the build is complaining on missing distribution apk? How does hassbian or the venv version build?
should be
apk --update add build-dependencies build-base && \
should be
pip3 install --no-cache-dir 'python_openzwave==0.4.11' --install-option="--flavor=ozwdev" && \
@winter
Thanks for pointing out some mistakes! I was used to editing docker run commands over multiple lines and missed the &&.
Now it seems like I can get somewhere. Lets see if this builds successfully.
@winter
Thanks for the proofreading! I was finally able to get this to build after installing some other packages.:partying_face:
If anyone else is interested:
dockerfile
RUN set -e && \
    apk --no-cache add --virtual build-dependencies coreutils linux-headers eudev-dev build-base && \
    rm -rf /var/lib/apt/lists/* && \
    pip3 install --upgrade cython==0.28.5 && \
    pip3 install --no-cache-dir 'python_openzwave==0.4.10' --install-option="--flavor=ozwdev" && \
I am not sure if anything can be optimized out (like rm -rf /var/lib/apt/lists/* ) or how to build via git but this builds successfully on a Pi 3 and reports:
$ head OZW_Log.txt
2018-11-06 21:51:45.540 Always, OpenZwave Version 1.5.0 Starting Up
2018-11-06 21:51:45.553 Info, Loading Localization File /usr/local/lib/python3.6/site-packages/python_openzwave/ozw_config/Localization.xml
2018-11-06 21:51:45.556 Always, Using Language Localization
2018-11-06 21:51:50.718 Info, Setting Up Provided Network Key for Secure Communications
2018-11-06 21:51:50.718 Warning, Failed - Network Key Not Set
2018-11-06 21:51:50.752 Info, Manufacturer_Specific.xml file Revision is 15
Improvements: Remove hard-coded values and Git flavor
FYI next release of HASS we wonā€™t need to update openzwave anymore, they have forked the repos and added the barrier support.
Link in case anyone wants to review.
@firstof9,
Thanks for sharing! It will be nice to stop needing to build the dev version each time. :partying_face:
Figuresā€¦ I just got this working last night lol.
Thanks to everyone who made this happen, especially @firstof9
