Linear NGDZ00-4 Garage Door
I am able to see the proper cover in HA now but openzwave changed the way it handles the door status:
                    <CommandClass id="102" name="COMMAND_CLASS_BARRIER_OPERATOR" version="1" issecured="true">
                            <Instance index="1" />
                            <Value type="list" genre="user" instance="1" index="1" label="Barrier State Label" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="$
                                    <Item label="Closed" value="0" />
                                    <Item label="Closing" value="1" />
                                    <Item label="Stopped" value="2" />
                                    <Item label="Opening" value="3" />
                                    <Item label="Opened" value="4" />
                                    <Item label="Unknown" value="5" />
                            </Value>
This causes it not to work in HA and this is as far as Iā€™ve be able to get so far.
Out of curiosity, since 0.46 and above are using their own OpenZwave files, is it possible to just replace a few config files to make this work?
Iā€™m not sure, I used information from this thread as well:
I actually just updated/added the files (4 in total) following Joshā€™s post and compiled/installed OZW again. Iā€™m still havenā€™t issues with HA not showing the cover control, but everything is working like it should under OZWCP.
Does your OZW_Log.txt say Openzwave 1.4xxxxxxxxxx or 1.5xxxxxx ?
It says 1.4xxxxxxxxxxx, but I only patched the files to the AIO release, I donā€™t assumed the version number would change.
1.5 is the Dev version that has Barrier support.
So is it possible to install the 1.5 dev version to get this working without a bunch of patches?
No it is not
Iā€™ve got my NGDZ00-4 working now with the dev version of openzwave lib now. For anyone interested hereā€™s the modified zwave.py file to allow it to work once youā€™ve compiled the dev version.
https://raw.githubusercontent.com/firstof9/home-assistant/dev/homeassistant/components/cover/zwave.py
Place it in your /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/cover/ directory.
@firstof9 I am assuming you have to add it securely for it to work, right?
Correct, you can do that from Home Assistantā€™s Zwave menu.
This works and currently only reports the door as ā€œOpenedā€ or ā€œClosedā€, I havenā€™t gotten around to modifying the code to show the fulls statuses reported by the library such as ā€œOpeningā€ and ā€œClosingā€.
Can you tell me how to compile the dev version? I have only ever used the AIO installer and the Hassbian script when I moved over to it.
Thanks.
@gregg098
The easiest way is probably to run a pre-built docker with Openzwave patched already. Take a look at the post from Colin O Dell here: https://www.colinodell.com/blog/201705/compiling-openzwave-home-assistant-045-docker.
In a nutshell, install docker on your linux system. Copy your configuration.yaml, automation.yaml, etc to your /home/homeassistant/.homeassistant directory and then run the below:ā€™
docker run -d --name=ā€œhome-assistantā€ -v /home/homeassistant/.homeassistant:/config --restart=always -itd --privileged --device /dev/ttyACM0 -v /etc/localtime:/etc/localtime:ro --net=host colinodell/home-assistant-with-barrier
I posted a script a few posts above:
Should do the trick.
Still no luck here. Had to change a few things to make it work with my Hassbian install, but no go.
What is your OZW_Log.txt showing on the first line?
And you made the modifications to the init.py file in /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave and cleared the /home/homeassistant/.homeassistant/deps/ directory as well?
First line shows
2017-07-09 14:09:13.460 Always, OpenZwave Version 1.4.2586 Starting Up
Yes, added the zwave.py file in the folder and cleared the deps directory. Not really a big deal at this point though. Will just wait for a stable z wave build with no modifications. Thanks for the help.
The dev version is very stable. Iā€™ll see about modifying the script to do everything that needs to be done to get it working.
Thank you very much for this! I as well are waiting for this. I can finally remove one of the many hubs that runs the house, Wink2 (I hate it) :slight_smile:
