Hello , I have n°1 Eastron ESP-W11 module (similar to Elfin W11) connected to n°2 DCM230 by RS485.
First DCM230 have address 001 and the second 002.
ESP-W11 have IP address 192.168.1.9
I can’t see the voltage and current values of the two meters by Home Assistant
Does it need baud rate etc as part of the configuration? Just asking as RS485 is a serial protocol and it should be clear in the examples in the manual, and the UART clue in your screen shot…
I didn’t include them in the code because the examples I found online didn’t include it.
That communication information is on the other settings page of ESP-W11. (I’m copying it from a video because I’m out of the house now.)
RS485 relies on 120ohm termination resisters on each end, and nowhere in between, for correct operation. Some boards have a jumper to select it, and often by default it is in, most people only having two devices on their serial bus, everything working fine out of the box. Having three or more terminated devices on the same bus will cause problems. This should also be in the manual. Probably around the same section where it discusses addressing, which you seem to have configured for unique addresses. Are all the devices on your RS485 bus allocated unique addresses to enable them to be individually addressed to read and write on the common bus? Are they matched the software configurations and integration?
The RS485 bus is widely used in industry and is very robust. You have to have a correct understanding of the principles - no AI or YouBoob shortcuts - you have to read the manual.
OK, I understand what you meant, I didn’t include it because the manual only talks about adding the resistor beyond 300 meters of connection.
I only have 1 meter from the W11 gateway to the two meters.
One 120ohm on the left and one on the right hand one across the wires where they connect to the unit is fine, and none for any others. It prevents signal corruption from spurious reflections. Very short distances can be just as bad as very long ones.
Matching your different units so they talk the same protocol, same speed, and correct addresses is your next challenge.
I find writing down your choices as you go through each manual makes it easier to plug in the values where needed in the respective configuration pages. Consistency is critical for success.
This is not software, or a HomeAssistant setting. It is part of RS485 bus wiring. I referred to your diagram which shows three devices daisy chained. This is part of your wiring to make sure the signals are consistent and error free. You need the resistors - only two of them, one on each end. Yes, it might work without them, but you may get intermittent or frequent transmission errors reported.
The two resistors you require are only a few cents each. Value 120ohms. Any wattage will do fine.
Sorry for the delay in replying, but I’ve been away on business.
I know what the resistors are for, but I didn’t add them because the device manual didn’t call for them for such short lengths.
Now I’ve placed them as you suggested: one on the master and one on the last slave.
I don’t think the problem is in the communication but in the code since I don’t know exactly how to program the yaml code part (which is the part I posted at the beginning of the post).
I just got back now, I’ll do a couple of tests and then I’ll post the yaml code for you if you have any suggestions.
