Link to Edit Scene from Automation
If one edits and automation and want to modify a scene triggered by said automation, such as Activate scene E1-SD Off in this automation, one has to click three or four times to get to the scene page AND then search for the scene (which you might forget what it is called because it is no longer in front f you). Shouldn’t there be a menu item on the … dropdown that is Edit underlying item that takes you directly to the scene (that way you don’t have to click click click to find the edit scene screen and then also have to search for the scene (which for those who are older and have less working memory, it a challenge at times).
