Hi
I am trying to link my Links Velop Wifi Router to Home assistant and i am unable to, anyone with knowledge can you please assist. I have no knowledge of YMAL at all. Thanks. the text i get read as follows: then theres YMAL Link provided
To use a Linksys Smart Wi-Fi Router in your Home Assistant installation, add the following to your configuration.yaml file. After changing the configuration.yaml file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services . Its entities are listed on the integration card itself and on the Entities tab.
the integration you are referencing (Linksys Smart Wi-Fi - Home Assistant I think) doesn’t seem to work with Velop based on the notes on that page…
maybe worth having a look at this custom integration for Velop…configurable through UI and has loads of Velop related feature you might use
it’s all in the thread I linked in my first reply to you…in the first post there is a link to the GitHub repository with all the instructions and details on how to get started…you will be much better served heading over there and reading through that as you’ll get a much better picture than posting here…
