List Codes on Kwikset SmartCode 888
I have 3 Kwikset SmartCode 888 locks and I was worried they would have some issues transitions from the old zwave integrations to zwave js but it looks like they migrated ok besides a few entities being unavailable.
I am looking to change the lock pins on my locks but it is not as simple it looks like on the new js integration. I see this can be used through the developer tools which would ok but I don’t know my slots to see which codes are set.
Is there a way to list the codes that are set for this lock?
Yes, in zwavejs2mqtt’s UI.
Thanks for the tip. Is this to view the codes or change or both? Thanks for recommending the add on
Also if I am using zwavejs2mqtt add on does that mean I cannot use zwavejs concurrently?
Correct, you run one or the other, NOT both
Both can be done via the zwavejs2mqtt UI.
