LiTime Solar MPPT Charge Controller data via BLE (ESPHome)
Hey all! I reverse-engineered the BLE commands and responses for core data for my LiTime MPPT solar charge controller:
I hope this helps someone; if you have questions, concerns, or suggestions, feel free to open an issue in the repo. Thanks!
This is just great! Amazing job Mark, never thought it would be integrable with home assistant.
I created a ESPhome shunt that is connected to the MPTT, now i can combine the code of both sensors.
Awesome! I’m curious to see where to take it :slightly_smiling_face:
I have this working and thanks for your work, but i was wondering about the text sensor in the litime_solar_mppt.yaml, have you managed to get this working or is there a work around, as this will not compile when i try to set it up giving a few errors ? those addition would be great in my setup.
# ESPHome Configuration for BT-LTMPPT4860 Solar Charge Controller
# specify values to be substitued into common components. todo: change these as desired.
substitutions:
  locationName: Battery Bay
  device: litime-solar
  deviceUnderscore: litime_solar
  deviceName: LiTime Solar
  deviceDescription: LiTime Solar BLE pull
  liTimeMacAddress: AA:BB:CC:DD:EE:FF # todo: replace with the MAC for your device
# Enable Home Assistant API
api:
  encryption:
    key: !secret encryption_key
preferences:
  flash_write_interval: 5min
logger:
  level: DEBUG
  baud_rate: 0 # disable logging over UART (maybe comment this out for initial upload)
ota:
  password: !secret ota_password
  platform: esphome
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_psk
  power_save_mode: light
  fast_connect: true    # don't bother scanning. When doing a full scan, can get watchdog timeouts, and we know who we're connecting to anyway
  use_address: !secret litime_solar_ip
  manual_ip:
    static_ip: !secret litime_solar_ip
    gateway: 192.168.1.1 # todo: replace with your gateway IP if yours is different
    subnet: 255.255.255.0
#region Buttons
button:
  - platform: restart
    name: $location $deviceName Restart
#endregion
esphome:
  includes:
    - litime_solar_mppt.h
  comment: $deviceDescription
esp32:
  board: nodemcu-32s
  framework:
    type: arduino
esp32_ble_tracker:
  scan_parameters:
    # We currently use the defaults to ensure Bluetooth
    # can co-exist with WiFi In the future we may be able to
    # enable the built-in coexistence logic in ESP-IDF
    active: true
# Using ble_client to get notifications from the device
  - platform: wifi_signal
    name: $location $deviceName WiFi Signal
    entity_category: diagnostic
    update_interval: 60s
  - platform: uptime
    name: $location $deviceName Uptime
    accuracy_decimals: 0
    unit_of_measurement: min
    filters:
      - lambda: return x / 60;
    name: "LiTime Battery Voltage"
    unit_of_measurement: "V"
    accuracy_decimals: 1
    device_class: voltage
    name: "LiTime Battery Current"
    unit_of_measurement: "A"
    accuracy_decimals: 2
    device_class: current
    name: "LiTime Battery Power"
    unit_of_measurement: "W"
    device_class: "power"
    name: "LiTime Controller Temperature"
    unit_of_measurement: "°C"
    device_class: "temperature"
    name: "LiTime Load Voltage"
    name: "LiTime Load Current"
    name: "LiTime Load Power"
    name: "LiTime PV Input Voltage"
    name: "LiTime Max Charging Power Today"
    name: "LiTime Power Generation Today"
    unit_of_measurement: "Wh"
    device_class: "energy"
    state_class: total_increasing
    name: "LiTime Running Days"
    unit_of_measurement: "days"
    name: "LiTime Total Power Generation"
    name: "LiTime Battery Level"
    unit_of_measurement: "%"
    device_class: "battery"
    lambda: |-
      if (id(battery_voltage).has_state()) {
        float voltage = id(battery_voltage).state;
        // Adjust these values based on your battery type
        float min_voltage = 11.0;
        float max_voltage = 14.4;
        return std::min(100.0f, std::max(0.0f, (voltage - min_voltage) / (max_voltage - min_voltage) * 100.0f));
      } else {
        return 0.0f;
# text_sensor:
#   - platform: template
#     name: "LiTime Controller Status"
#     id: controller_status
#     lambda: |-
#       switch (id(mppt_data).controller_mode) {
#         case 0: return {"Standby"};
#         case 1: return {"Float"};
#         case 2: return {"Boost"};
#         case 3: return {"Equalization"};
#         case 4: return {"Absorption"};
#         default: return {"Unknown"};
# Custom component to handle BLE notifications
  - platform: ble_client
    ble_client_id: ltmppt_client
    internal: true
    service_uuid: "ffe0"
    characteristic_uuid: "ffe1"
    type: characteristic
    notify: true
    update_interval: never
    # on_notify:
    #   then:
    #     - lambda: |-
    #         ESP_LOGW("ble_client.notify", "x: %.2f", x);
    lambda: |-
      // Display the hex string for debugging.
      std::vector<uint8_t> data = x;
      String hex_string = "";
      for (size_t i = 0; i < x.size(); ++i) {
        char hex_buffer[3];
        snprintf(hex_buffer, sizeof(hex_buffer), "%02X", data[i]);
        hex_string += hex_buffer;
        if (i % 2 == 1 && i != data.size() - 1) {
          hex_string += " ";  // Insert a space every two bytes
      uint8_t arr_size = x.size();
      ESP_LOGD("LOG_TAG", "Hexadecimal string: %s", hex_string.c_str());
      HandleResponseData(x);
      return 0.0; // this sensor isn't actually used other than to hook into raw value and publish to template sensors
# Add a switch to control the DC load
switch:
    name: "LiTime DC Load"
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    turn_on_action:
      - ble_client.ble_write:
          service_uuid: "FFE0"
          characteristic_uuid: "FFE1"
          value: !lambda |-
            ESP_LOGI("mppt", "Sending load ON command");
            // Command to turn on load: 010601200001483c
            vector<uint8_t> request = {0x01, 0x06, 0x01, 0x20, 0x00, 0x01, 0x48, 0x3c};
            return request;
    turn_off_action:
          value: !lambda |-
            ESP_LOGI("mppt", "Sending load OFF command");
            // Command to turn off load: 01060120000089fc
            vector<uint8_t> request = {0x01, 0x06, 0x01, 0x20, 0x00, 0x00, 0x89, 0xfc};
            return request;
# Define the BLE client for the LTMPPT4860
ble_client:
  - mac_address: ${liTimeMacAddress}
    auto_connect: true
    on_connect:
      then:
        - logger.log:
            format: "BLE client connected to LiTime MPPT"
            level: DEBUG
    on_disconnect:
      then:
        - logger.log:
            format: "BLE client disconnected from LiTime MPPT"
            level: DEBUG
# Run this when we connect to the device
interval:
  - interval: 10s
    then:
          value: [0x01, 0x03, 0x01, 0x01, 0x00, 0x13, 0x54, 0x3B]
          # example output: 0103 2600 6400 8E04 2E00 9719 FF00 0000 0000 0003 1803 6805 0400 0000 0400 0000 0300 0018 2A00 0000 00E1 65
I haven’t looked at it since I first wrote the integration, and I don’t know when I’ll have a chance. But if you are about to get it working, please feel free to submit a pull request to the project.
Thanks!
Thank you for the quick reply and i will do.
