http://homeassistant.local:8123/lovelace/0?edit=1 gives me a “loading data” screen. Is there a way I can reset my whole home assistant ? I have a backup, and I am running HA on proxmox
One way to do it would be to create a new virtual machine with HA, then do a restore to that. I would rather look into why it is misbehaving if I were you though. Can you access it by ip:8123?
I can login, but I still get loading data
Can you check logs? If not, try a restore.
Have you tried a browser refresh first?
I cannot go the the logs. i only get the loading data screen
i tried it on different browsers … Same problem
