trying to create a local calendar with python yes AI help a bit
def create_local_calendar(name, ha_url, token):
url = f"{ha_url}/api/local_calendar"
headers = {
"Authorization": f"Bearer {token}",
"Content-Type": "application/json"
payload = {
"name": name,
"type": "local"
r = requests.post(url, headers=headers, json=payload)
if r.status_code in (200, 201):
print(f"Created calendar: {name}")
else:
print(f"Failed to create calendar: {r.status_code} {r.text}")
def check_calendar_features(entity_id, ha_url, token):
url = f"{ha_url}/api/states/{entity_id}"
headers = {"Authorization": f"Bearer {token}"}
r = requests.get(url, headers=headers)
if r.status_code != 200:
print("Calendar not found")
return None
data = r.json()
features = data["attributes"].get("supported_features", None)
print(f"{entity_id} supported_features = {features}")
return features
def ensure_writable_calendar():
calendar_name = "Roster Write"
entity_id = "calendar.roster_write"
print("🔍 Checking if writable calendar exists...")
# Try checking features first
features = check_calendar_features(entity_id, HA_URL, HA_TOKEN)
if features in (3, 5):
print("✅ Writable calendar already exists.")
return entity_id
print("⚠️ Calendar not writable or missing. Creating new one...")
# Create the calendar
create_local_calendar(calendar_name, HA_URL, HA_TOKEN)
# Re-check
print("🎉 Writable calendar created successfully!")
return entity_id
print("❌ Still not writable — HA created an ICS calendar again.")
return None
but im getting these errors
HA Sync: Fetching roster and pushing to HA...
Calendar not found
Failed to create calendar: 404 404: Not Found
Calendar not found
Ensured writable calendar: None
❌ Cannot continue — no writable calendar available.
what am i missing and what manual should i be reading next
