I just upgraded from 2025.10.3 to 2025.10.4, and my local file camera is no longer working, because the service call to update the file path has gone ?
However, it turns out that this isnt anything to do with the update, its just a bit of a coincidence.
When you configure the integration, you provide a path to an image. I ran a script to clean up old images, and the integration failed to start because that image is no longer available.
Short of configuring the local_file camera integration with a static image, is there a better way to get around this?
