Hi there,
We get quite a bit of flooding around where we live which affects road access.
There’s helpfully a couple of webcams installed which show the state of the roads, but there website is littered with adverts.
Can anyone tell me a way of scraping the live image and including in Home Assistant - the iframe option to include the website doesn’t work. Is the site using X-Frame headers to prevent the embedding of infromation?
Hi-def webcam at Gloucester offering up to the second live imagery on River Severn. With regular river reports from the area, and an extensive archive of images from the past days, months and even years, this is the greatest way to view the beauty of...
Thanks,
Try api environment.data.gov.uk/flood-monitoring/id/stations/2165.json
It will give the height so I assume that will also indicate flooding?
EDIT: after a 2nd thought… it will likely not … a picture would show you if flooding happened in that area.
Thanks. I’m already using the Environment Agency integration to get river levels.
I had hoped to also incorporate the webcam but it seems to be tricky to get the live feed in.
The link just keeps reverting to ab ad which I can’t seem to bypass:
You can try something like this but I would not know how sensitive it is to a correct timestamp…the timestamp you can add as part of a command_line with a template
curl -L \
-H "Referer: https://www.farsondigitalwatercams.com/" \
-H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/144.0.0.0 Safari/537.36 Edg/144.0.0.0" \
"https://images-cnd0ajgjbebpgjbe.z03.azurefd.net/realtime-images/Gloucester-River7/current1.jpg?rid=1770645270" \
EDIT: then you should download it to your www folder from which you can then use it in HA
Or this may work too, I have not the time to check if it is actaully pulling the correct latest picture
curl -L \
-H "User-Agent: Mozilla/5.0" \
"https://images-cnd0ajgjbebpgjbe.z03.azurefd.net/realtime-images/Gloucester-River7/current1.jpg?rid=$(date +%s)" \
Thanks - yes, did something similar (created and edited a script in nano editor):
It’s pulling back the jpg - but the jpg of the advert not of the webcam unfortunately.
#!/bin/bash
curl -s -L \
-H "Referer: https://www.farsondigitalwatercams.com/locations/gloucester" \
-H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36" \
-H "Accept: image/avif,image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8" \
-H "Accept-Language: en-GB,en-US;q=0.9,en;q=0.8" \
-H "Cache-Control: no-cache" \
-H "Pragma: no-cache" \
-o /config/www/gloucester_webcam.jpg
luxia
(luxia)
February 9, 2026, 2:30pm
7
The webpage card might work?
Odd - it pulls the camera picture not the image of the GoPro ad?
Indeed… I get a picture, but it does not show any time only a date so no clue what it is (other than ‘today’ and after sunrise )
The op wants just the picture, not the clutter around it.
Brilliant - done it!
Now just to get it to run the script based on a specified time I want it to run (e.g. every hour).
Thanks ever so much! You’ve been so helpful.
Great…tick the solution box please so others can find this as a possible (!?) solution too (i.e. bypassing ‘stuff’). I was in Gloucester 5y ago as a tourist …which sort of drew my attention to your challenge
the command_line lets you set an scan_interval: 3600
Flooded today which is why I’m onto Home Assistant (just as well it’s also a day off for me!).
Will do - thanks ever so much.
