Local fully autonomous solution for Resmed data extraction
I wanted my CPAP data to just show up alongside the rest of my home sensors the same way my thermostat or my weather station does. No intervention, no remembering to check, no pulling cards. And I that way I could setup automations based on when the system detected the sleep session started or ended and the data associated to it.
You set it up once and never touch it again. Every 2 minutes (configurable) while you’re using the machine:
  1. It connects to the SD card over WiFi (via an ezShare adapter, the cpap doesn’t even know it’s there)
  2. Detects if the machine is actively writing a file before downloading (so it doesn’t grab a half-written checkpoint)
  3. Groups the checkpoint files into sessions using 2-hour gap detection
  4. Parses everything using the same algorithms OSCAR uses, breath detection, flow analysis, tidal volume, minute ventilation, flow limitation scoring
  5. Saves to PostgreSQL and publishes to MQTT with Home Assistant auto-discovery
As a result You go to sleep. You wake up. Your dashboard already has the full session: AHI breakdown, leak percentiles, respiratory metrics, SpO2 trends, usage hours. 46 sensors, all populated automatically. No manual efforts.
And something i love is the structure of the code allows for querying te data further for the pressure adjustment, for behavior at specific times of the night or even tied that to other home events.
When the machine stops writing (session ends), it also grabs the STR.edf file, ResMed’s own daily summary with the official AHI, Cheyne-Stokes percentage, mask on/off timestamps, and cumulative lifetime hours. Stuff you can’t get from the breathing files alone.
After the first post, several people asked about running this without buying the WiFi SD card hardware. Maybe you already have your data somewhere, just copy the card to a NAS, or mount it via SMB, or just dump it to a folder on your PC periodically.
So now there are three ways to run it:
1.ezShare + Pi fully automatic zero intervention
The original setup. Pi Zero 2 W with a USB WiFi dongle one interface stays on your home network, the other connects to the ezShare card inside the machine. Data flows continuously while you sleep. You never touch the SD card.
  1. Local directory semi automatic no special hardware
Point it at a folder containing your DATALOG directory. Could be an SMB mount, a USB card reader that stays plugged in, or just a folder you occasionally copy files to. It polls for changes by file size and picks up new data automatically.
Two environment variables in the system config would changee to support this:
CPAP_SOURCE=local
CPAP_LOCAL_DIR=/path/to/your/DATALOG
  1. One shot reparse good for bulks historical data.
Already have months of data sitting on a drive? Load it all in one command:
hms_cpap --reparse /path/to/DATALOG 2025-01-01 2026-03-01
It scans every date folder in the range, groups files into sessions, and saves parsed data to the database. Good for backfilling history or fixing bad data.
For docker (easiest way to get started)
docker run -d \
-v /path/to/your/DATALOG:/data/DATALOG \
-e CPAP_SOURCE=local \
-e CPAP_LOCAL_DIR=/data/DATALOG \
-e CPAP_DEVICE_ID=cpap_resmed_YOURSERIAL \
-e DB_HOST=your-postgres \
-e MQTT_BROKER=your-mqtt \
ghcr.io/hms-homelab/hms-cpap:latest
Image on GHCR, builds for amd64 and arm64.
It shows 46 sensors in Home Assistant
  • Realtime: (while machine is on): flow, pressure, leak, SpO2, heart rate, respiratory rate, tidal volume, minute ventilation, session active indicator
  • Session summary (after you turn it off): AHI with full breakdown (obstructive/central/hypopnea/RERA/clear airway), avg
and max event duration, pressure and leak percentiles, usage hours and percentage of 8h target, OSCAR-calculated breathmetrics
  • STR daily (official ResMed data): real AHI + delta vs calculated, Cheyne-Stokes minutes, mask on/off count, cumulative lifetime hours, device settings
OSCAR is the best tool for sitting down and analyzing a specific night zooming into waveforms, looking at individual events, adjusting your therapy. HMS-CPAP is for the other 364 days when you just want to glance at a dashboard and see that everything looks normal. Continuous monitoring vs deep analysis. They complement each other.
Thinking about adding ML for pattern detection (predict bad nights from early session data, flag anomalies in trends) and already have a working model of a different extractor hardware that doesn’t require a pi, a dual esp32 bundle, cheaper and smaller.
Repo: GitHub - hms-homelab/hms-cpap: ResMed CPAP data collection service for Home Assistant. Collects therapy data via ez Share WiFi SD card with OSCAR-compatible metrics. · GitHub
If anyone gives the Docker image a shot let me know how it goes especially if you hit issues with your ResMed model.
Built and tested against AirSense 10 but the EDF format should be the same across the lineup.
Thanks for this! Can you help me understand the implications of using just the EZ Share SD card? You mention WIFI switching. BbDoes that mean HA will periodically disconnect from network to check for sleep data? What if the hub is hardwired with Ethernet?
Also, do you think this would also work for a BiPAP machine (ResMed AirCurve 11)?
what hardware do you recommend to run this on? (i have purchased the FYSETC SD WiFi Pro) and am waiting on it to arrive currently running HAOS on raspberry pi and don’t have anything else other than a windows system to run this on
@aamat09 I think I know the answer but will ask anyway. Is it likely to work with a Resmed Air Mini? The Air Mini syncs data from the device to the phone app via bluetooth.
