So I tried a bunch more tests on the new version and old version. On the old version, I switched to having fixed bitrate and 1 iframe per frame and was able to run for 2 days on one camera without mask which is the best so far. It never got stuck, I shut it down manually to try the new version… So that’s very promising.
On the new FFMPEG version I tried to go whole hog with 4 1080p streams from the synology (which I changed to fixed bitrate) and masks but it only lasted about 9 hours before giving me the same errors about closing and opening the streams (CPU use for this use case dropped from about 44% on old version to 30% on new for those interested).
Here’s the log:
2019-07-15 10:59:23 stderr 172.11.0.1 - - [15/Jul/2019 10:59:23] "GET /back/best_person.jpg HTTP/1.1" 200 -
2019-07-15 10:59:23 stderr 172.11.0.1 - - [15/Jul/2019 10:59:23] "GET /left/best_person.jpg HTTP/1.1" 200 -
2019-07-15 10:59:13 stderr 172.11.0.1 - - [15/Jul/2019 10:59:13] "GET /front/best_person.jpg HTTP/1.1" 200 -
2019-07-15 10:59:13 stderr 172.11.0.1 - - [15/Jul/2019 10:59:13] "GET /back/best_person.jpg HTTP/1.1" 200 -
2019-07-15 10:59:13 stderr 172.11.0.1 - - [15/Jul/2019 10:59:13] "GET /right/best_person.jpg HTTP/1.1" 200 -
2019-07-15 10:59:13 stderr 172.11.0.1 - - [15/Jul/2019 10:59:13] "GET /left/best_person.jpg HTTP/1.1" 200 -
2019-07-15 10:59:07 stdout ffmpeg -hide_banner -loglevel panic -avoid_negative_ts make_zero -fflags nobuffer -flags low_delay -strict experimental -fflags +genpts -rtsp_transport tcp -stimeout 5000000 -use_wallclock_as_timestamps 1 -i rtsp://uname:[email protected] :554/Sms=4.unicast -f rawvideo -pix_fmt rgb24 pipe:
2019-07-15 10:59:07 stdout Starting a new capture process...
2019-07-15 10:59:07 stdout Creating a new capture process...
2019-07-15 10:59:07 stdout Terminating the existing capture process...
2019-07-15 10:59:07 stdout last frame is more than 2 seconds old, restarting camera capture...
2019-07-15 10:59:07 stdout ffmpeg -hide_banner -loglevel panic -avoid_negative_ts make_zero -fflags nobuffer -flags low_delay -strict experimental -fflags +genpts -rtsp_transport tcp -stimeout 5000000 -use_wallclock_as_timestamps 1 -i rtsp://uname:[email protected] :554/Sms=2.unicast -f rawvideo -pix_fmt rgb24 pipe:
2019-07-15 10:59:06 stdout ffmpeg -hide_banner -loglevel panic -avoid_negative_ts make_zero -fflags nobuffer -flags low_delay -strict experimental -fflags +genpts -rtsp_transport tcp -stimeout 5000000 -use_wallclock_as_timestamps 1 -i rtsp://uname:[email protected] :554/Sms=1.unicast -f rawvideo -pix_fmt rgb24 pipe:
2019-07-15 10:59:06 stdout Starting a new capture process...
2019-07-15 10:59:06 stdout Creating a new capture process...
2019-07-15 10:59:06 stdout Terminating the existing capture process...
2019-07-15 10:59:06 stdout last frame is more than 2 seconds old, restarting camera capture...
2019-07-15 10:59:06 stdout ffmpeg -hide_banner -loglevel panic -avoid_negative_ts make_zero -fflags nobuffer -flags low_delay -strict experimental -fflags +genpts -rtsp_transport tcp -stimeout 5000000 -use_wallclock_as_timestamps 1 -i rtsp://uname:[email protected] :554/Sms=3.unicast -f rawvideo -pix_fmt rgb24 pipe:
2019-07-15 10:59:03 stderr 172.11.0.1 - - [15/Jul/2019 10:59:03] "GET /right/best_person.jpg HTTP/1.1" 200 -
2019-07-15 10:59:03 stderr 172.11.0.1 - - [15/Jul/2019 10:59:03] "GET /back/best_person.jpg HTTP/1.1" 200 -
2019-07-15 10:59:03 stderr 172.11.0.1 - - [15/Jul/2019 10:59:03] "GET /left/best_person.jpg HTTP/1.1" 200 -
2019-07-15 10:59:03 stderr 172.11.0.1 - - [15/Jul/2019 10:59:03] "GET /front/best_person.jpg HTTP/1.1" 200 -
I’m going to take out the masks and try again with the new version on 1080p but I suspect I will need to use the substream on either version.
By default, I reduce the logging of ffmpeg so it doesn’t flood the logs. I would try removing this line , building and running frigate with one camera. FFmpeg should output lots more information about what it is doing. My guess is that at some point FFmpeg starts to have trouble getting valid frames from your camera and discards the corrupt frames. You could also copy and paste that ffmpeg command from the logs and run it on any machine with > /dev/null
appended to the end. That should do the same thing.
Also, you can probably add the hwaccel parameters from the new example config if your synology has an Intel CPU. I would be curious to see if that reduces the CPU usage further when running everything.
billimek
(Jeff Billimek)
July 15, 2019, 11:53am
368
Regarding the regions configuration:
I have an rtsp camera stream that is a 704x576 image and want to ‘cover’ the entire image for person detection. Is it better to:
Define a single ‘region’ that is:
- size: 704
x_offset: 0
y_offset: 0
min_person_area: 5000
threshold: 0.5
or, define 6 different ‘300’ sized regions to ensure complete coverage of the frame?
Regions should be sized so that an entire person will be in the square and fill it as much as possible. Detection works better on whole people than it does on legs or heads. If people are far away, you will be better off with smaller regions. Larger regions are better when people are close. Also, you can’t have a region that goes beyond the boundaries of the image.
billimek
(Jeff Billimek)
July 15, 2019, 12:19pm
370
Thanks @blakeblackshear ,
The region ‘size’ represents a square ‘box’, correct?
I’m trying to figure out how to best capture a person in an image that is a rectangle (e.g. 704x576). The scene is relatively close-up (it’s a covered proch):
The example above has 4 ‘300’ sized regions offset 104px from the left so that they are bounded inside the image directly. I’d prefer to have complete coverage.
As you say, having the smaller boxes will likely not cover a person standing close to the camera, so I’m trying to figure out the best way to define the regions.
Regions can overlap too. You may detect a person in multiple regions, but it will work. Maybe one large region to cover the whole area, and then a smaller one to cover the gate area.
billimek
(Jeff Billimek)
July 15, 2019, 5:36pm
372
In case any of you are interested how this performs on an Odroid-H2, here is what it looks like with 5 diff video feeds (each at 5fps), ~80% CPU using the blakeblackshear/frigate:0.2.0-beta
docker image:
Do you have the hardware acceleration enabled in your config?
What do you gain by running your setup in kubernetes? I am just running compose, but use k8s at work.
I am now running the 4 1080p streams (8 zones) without masks and it looks like it’s holding up pretty well, it’s already made it a few hours past where it gave up with the masks… I’ll leave it running for a couple days and see if it manages… If it does, I’d have to assume it’s some issues with masks as I’ve changed nothing else… Next test I do I will do as you prescribe with the in depth logging and hardware acceleration.
billimek
(Jeff Billimek)
July 15, 2019, 8:58pm
376
@blakeblackshear ,
I think so - I’m using the following in the config. But think you mentioned there are possibly different values we should use for intel-based GPU accel. I’m going to dig into that now. Also, after closing all the preview windows the CPU usage settled-down to about 37% FYI.
ffmpeg_hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- /dev/dri/renderD128
- -hwaccel_output_format
- yuv420p
I’m not running frigate via k8s now, but instead am running the docker container directly on a k8s node where I have the coral plugged-in via USB. If I get this working well, my plan is to explore wrapping a helm chart around frigate and deploying that way with a scheduling setting to only schedule the pod(s) to the node(s) where the coral is directly plugged-in.
The reason for this extra layer/complication is simply because all my other stuff (home assistant, mqtt, etc) are running in k8s already.
tc23
July 15, 2019, 9:12pm
377
Do you have to change the image
portion of the docker-compose.yaml to reflect the beta, or leave it as frigate:latest? I got errors when I tried to change to beta as the image, but wasn’t sure if this was proper
Latest is still the older, non beta version. You need to update to the beta image.
37% is more like what I would expect. The mjpeg stream is on demand because encoding the mjpeg video stream is CPU intensive. Looking at the CPU usage for your ffmpeg processes, I think you are getting hwaccel. Low single digit CPU utilization per camera seems about right. If you scroll that to the right, you should see the additional params passed to ffmpeg.
Kyle
July 15, 2019, 10:38pm
380
Thanks for the push with the hardware acceleration support. My CPU load dropped from 2.4 to 1.4 with it enabled.
tc23
July 15, 2019, 10:41pm
381
Ok, I used the docker pull command and then changed my docker-compose to relfect image: frigate:0.2.0-beta
, then ran docker-compose up
and got the following error:
Pulling camera_1 (frigate:0.2.0-beta)...
ERROR: The image for the service you're trying to recreate has been removed. If you continue,
volume data could be lost. Consider backing up your data before continuing.
Continue with the new image? [yN]y
ERROR: pull access denied for frigate, repository does not exist or may require 'docker login'``
I did this within the frigate dir that I was running the latest non-beta image
Needs to be blakeblackshear/frigate:0.2.0-beta
uid0
July 16, 2019, 10:59am
384
Using your 0.2.0-beta, I get the following trying to set up the new Raspberry Pi 4 (Hikvision Cams, works on my desktop):
pi@raspberrypi:~ $ sudo docker run --rm --privileged -v /dev/bus/usb:/dev/bus/usb -v /home/pi/config:/config:ro -p 5000:5000 -e RTSP_PASSWORD='********' frigate:latest
On connect called
[rtsp @ 0x164fcd0] method DESCRIBE failed: 404 Not Found
File "detect_objects.py", line 99, in <module>
main()
File "detect_objects.py", line 53, in main
cameras[name] = Camera(name, config, prepped_frame_queue, client, MQTT_TOPIC_PREFIX)
File "/opt/frigate/frigate/video.py", line 137, in __init__
self.frame_shape = get_frame_shape(self.rtsp_url)
File "/opt/frigate/frigate/video.py", line 102, in get_frame_shape
frame_shape = frame.shape
AttributeError: 'NoneType' object has no attribute 'shape
Any ideas?
So, it’s running now with the debug setup for video.py. I also tried to enable hw acceleration but the container wouldn’t start with it, so went back to running without.
There’s a few Past duration too large errors in there…:
|2019-07-16 10:57:43|stderr|frame= 1122 fps=4.0 q=-0.0 size= 6816150kB time=00:04:48.50 bitrate=193545.6kbits/s dup=1 drop=0 speed=1.02x frame= 1124 fps=4.0 q=-0.0 size= 6828300kB time=00:04:49.00 bitrate=193555.1kbits/s dup=1 drop=0 speed=1.02x frame= 1127 fps=4.0 q=-0.0 size= 6846525kB time=00:04:49.75 bitrate=193569.4kbits/s dup=1 drop=0 speed=1.02x frame= 1130 fps=4.0 q=-0.0 size= 6864750kB time=00:04:50.50 bitrate=193583.6kbits/s dup=1 drop=0 speed=1.02x frame= 1132 fps=4.0 q=-0.0 size= 6876900kB time=00:04:51.00 bitrate=193593.0kbits/s dup=1 drop=0 speed=1.02x frame= 1135 fps=4.0 q=-0.0 size= 6895125kB time=00:04:51.75 bitrate=193607.1kbits/s dup=1 drop=0 speed=1.02x Past duration 0.991142 too large|
|2019-07-16 10:57:40|stderr|frame= 1107 fps=4.0 q=-0.0 size= 6725025kB time=00:04:44.75 bitrate=193472.9kbits/s dup=1 drop=0 speed=1.02x frame= 1110 fps=4.0 q=-0.0 size= 6743250kB time=00:04:45.50 bitrate=193487.6kbits/s dup=1 drop=0 speed=1.02x frame= 1112 fps=4.0 q=-0.0 size= 6755400kB time=00:04:46.00 bitrate=193497.3kbits/s dup=1 drop=0 speed=1.02x frame= 1115 fps=4.0 q=-0.0 size= 6773625kB time=00:04:46.75 bitrate=193511.9kbits/s dup=1 drop=0 speed=1.02x frame= 1117 fps=4.0 q=-0.0 size= 6785775kB time=00:04:47.25 bitrate=193521.6kbits/s dup=1 drop=0 speed=1.02x frame= 1120 fps=4.0 q=-0.0 size= 6804000kB time=00:04:48.00 bitrate=193536.0kbits/s dup=1 drop=0 speed=1.02x Past duration 0.948708 too large|
|2019-07-16 10:57:36|stderr|frame= 1074 fps=4.0 q=-0.0 size= 6524550kB time=00:04:36.50 bitrate=193306.0kbits/s dup=1 drop=0 speed=1.02x frame= 1076 fps=4.0 q=-0.0 size= 6536700kB time=00:04:37.00 bitrate=193316.4kbits/s dup=1 drop=0 speed=1.02x frame= 1079 fps=4.0 q=-0.0 size= 6554925kB time=00:04:37.75 bitrate=193331.9kbits/s dup=1 drop=0 speed=1.02x frame= 1081 fps=4.0 q=-0.0 size= 6567075kB time=00:04:38.25 bitrate=193342.2kbits/s dup=1 drop=0 speed=1.02x frame= 1084 fps=4.0 q=-0.0 size= 6585300kB time=00:04:39.00 bitrate=193357.6kbits/s dup=1 drop=0 speed=1.02x frame= 1087 fps=4.0 q=-0.0 size= 6603525kB time=00:04:39.75 bitrate=193372.9kbits/s dup=1 drop=0 speed=1.02x frame= 1090 fps=4.0 q=-0.0 size= 6621750kB time=00:04:40.50 bitrate=193388.1kbits/s dup=1 drop=0 speed=1.02x frame= 1092 fps=4.0 q=-0.0 size= 6633900kB time=00:04:41.00 bitrate=193398.3kbits/s dup=1 drop=0 speed=1.02x frame= 1095 fps=4.0 q=-0.0 size= 6652125kB time=00:04:41.75 bitrate=193413.3kbits/s dup=1 drop=0 speed=1.02x frame= 1097 fps=4.0 q=-0.0 size= 6664275kB time=00:04:42.25 bitrate=193423.4kbits/s dup=1 drop=0 speed=1.02x frame= 1100 fps=4.0 q=-0.0 size= 6682500kB time=00:04:43.00 bitrate=193438.3kbits/s dup=1 drop=0 speed=1.02x frame= 1103 fps=4.0 q=-0.0 size= 6700725kB time=00:04:43.75 bitrate=193453.2kbits/s dup=1 drop=0 speed=1.02x frame= 1105 fps=4.0 q=-0.0 size= 6712875kB time=00:04:44.25 bitrate=193463.1kbits/s dup=1 drop=0 speed=1.02x Past duration 0.990578 too large|
|2019-07-16 10:57:28|stderr|frame= 1059 fps=4.0 q=-0.0 size= 6433425kB time=00:04:32.75 bitrate=193226.8kbits/s dup=1 drop=0 speed=1.02x frame= 1062 fps=4.0 q=-0.0 size= 6451650kB time=00:04:33.50 bitrate=193242.8kbits/s dup=1 drop=0 speed=1.02x frame= 1064 fps=4.0 q=-0.0 size= 6463800kB time=00:04:34.00 bitrate=193253.5kbits/s dup=1 drop=0 speed=1.02x frame= 1067 fps=4.0 q=-0.0 size= 6482025kB time=00:04:34.75 bitrate=193269.3kbits/s dup=1 drop=0 speed=1.02x frame= 1069 fps=4.0 q=-0.0 size= 6494175kB time=00:04:35.25 bitrate=193279.9kbits/s dup=1 drop=0 speed=1.02x frame= 1072 fps=4.0 q=-0.0 size= 6512400kB time=00:04:36.00 bitrate=193295.6kbits/s dup=1 drop=0 speed=1.02x Past duration 0.975243 too large|
|2019-07-16 10:57:24|stderr|frame= 1057 fps=4.0 q=-0.0 size= 6421275kB time=00:04:32.25 bitrate=193216.1kbits/s dup=1 drop=0 speed=1.02x Past duration 0.932610 too large|
|2019-07-16 10:57:23|stderr|frame= 1043 fps=4.0 q=-0.0 size= 6336225kB time=00:04:28.75 bitrate=193139.9kbits/s dup=1 drop=0 speed=1.02x frame= 1046 fps=4.0 q=-0.0 size= 6354450kB time=00:04:29.50 bitrate=193156.4kbits/s dup=1 drop=0 speed=1.02x frame= 1048 fps=4.0 q=-0.0 size= 6366600kB time=00:04:30.00 bitrate=193167.4kbits/s dup=1 drop=0 speed=1.02x frame= 1051 fps=4.0 q=-0.0 size= 6384825kB time=00:04:30.75 bitrate=193183.7kbits/s dup=1 drop=0 speed=1.02x frame= 1053 fps=4.0 q=-0.0 size= 6396975kB time=00:04:31.25 bitrate=193194.5kbits/s dup=1 drop=0 speed=1.02x frame= 1055 fps=4.0 q=-0.0 size= 6409125kB time=00:04:31.75 bitrate=193205.3kbits/s dup=1 drop=0 speed=1.02x Past duration 0.985588 too large|
|2019-07-16 10:57:20|stderr|frame= 1027 fps=4.0 q=-0.0 size= 6239025kB time=00:04:24.75 bitrate=193050.4kbits/s dup=1 drop=0 speed=1.02x frame= 1030 fps=4.0 q=-0.0 size= 6257250kB time=00:04:25.50 bitrate=193067.4kbits/s dup=1 drop=0 speed=1.02x frame= 1032 fps=4.0 q=-0.0 size= 6269400kB time=00:04:26.00 bitrate=193078.7kbits/s dup=1 drop=0 speed=1.02x frame= 1035 fps=4.0 q=-0.0 size= 6287625kB time=00:04:26.75 bitrate=193095.5kbits/s dup=1 drop=0 speed=1.02x frame= 1037 fps=4.0 q=-0.0 size= 6299775kB time=00:04:27.25 bitrate=193106.7kbits/s dup=1 drop=0 speed=1.02x frame= 1039 fps=4.0 q=-0.0 size= 6311925kB time=00:04:27.75 bitrate=193117.8kbits/s dup=1 drop=0 speed=1.02x frame= 1041 fps=4.0 q=-0.0 size= 6324075kB time=00:04:28.25 bitrate=193128.9kbits/s dup=1 drop=0 speed=1.02x Past duration 0.938438 too large|
|2019-07-16 10:57:16|stderr|frame= 994 fps=4.0 q=-0.0 size= 6038550kB time=00:04:16.50 bitrate=192856.9kbits/s dup=1 drop=0 speed=1.02x frame= 996 fps=4.0 q=-0.0 size= 6050700kB time=00:04:17.00 bitrate=192869.0kbits/s dup=1 drop=0 speed=1.02x frame= 999 fps=4.0 q=-0.0 size= 6068925kB time=00:04:17.75 bitrate=192887.0kbits/s dup=1 drop=0 speed=1.02x frame= 1001 fps=4.0 q=-0.0 size= 6081075kB time=00:04:18.25 bitrate=192899.0kbits/s dup=1 drop=0 speed=1.02x frame= 1004 fps=4.0 q=-0.0 size= 6099300kB time=00:04:19.00 bitrate=192916.9kbits/s dup=1 drop=0 speed=1.02x frame= 1007 fps=4.0 q=-0.0 size= 6117525kB time=00:04:19.75 bitrate=192934.6kbits/s dup=1 drop=0 speed=1.02x frame= 1009 fps=4.0 q=-0.0 size= 6129675kB time=00:04:20.25 bitrate=192946.4kbits/s dup=1 drop=0 speed=1.02x frame= 1011 fps=4.0 q=-0.0 size= 6141825kB time=00:04:20.75 bitrate=192958.1kbits/s dup=1 drop=0 speed=1.02x frame= 1014 fps=4.0 q=-0.0 size= 6160050kB time=00:04:21.50 bitrate=192975.6kbits/s dup=1 drop=0 speed=1.02x frame= 1016 fps=4.0 q=-0.0 size= 6172200kB time=00:04:22.00 bitrate=192987.3kbits/s dup=1 drop=0 speed=1.02x frame= 1019 fps=4.0 q=-0.0 size= 6190425kB time=00:04:22.75 bitrate=193004.6kbits/s dup=1 drop=0 speed=1.02x frame= 1021 fps=4.0 q=-0.0 size= 6202575kB time=00:04:23.25 bitrate=193016.1kbits/s dup=1 drop=0 speed=1.02x frame= 1024 fps=4.0 q=-0.0 size= 6220800kB time=00:04:24.00 bitrate=193033.3kbits/s dup=1 drop=0 speed=1.02x Past duration 0.995766 too large|
|2019-07-16 10:57:08|stderr|frame= 962 fps=4.0 q=-0.0 size= 5844150kB time=00:04:08.50 bitrate=192657.0kbits/s dup=1 drop=0 speed=1.02x frame= 964 fps=4.0 q=-0.0 size= 5856300kB time=00:04:09.00 bitrate=192669.9kbits/s dup=1 drop=0 speed=1.02x frame= 967 fps=4.0 q=-0.0 size= 5874525kB time=00:04:09.75 bitrate=192689.1kbits/s dup=1 drop=0 speed=1.02x frame= 969 fps=4.0 q=-0.0 size= 5886675kB time=00:04:10.25 bitrate=192701.9kbits/s dup=1 drop=0 speed=1.02x frame= 972 fps=4.0 q=-0.0 size= 5904900kB time=00:04:11.00 bitrate=192720.9kbits/s dup=1 drop=0 speed=1.02x frame= 975 fps=4.0 q=-0.0 size= 5923125kB time=00:04:11.75 bitrate=192739.8kbits/s dup=1 drop=0 speed=1.02x frame= 977 fps=4.0 q=-0.0 size= 5935275kB time=00:04:12.25 bitrate=192752.3kbits/s dup=1 drop=0 speed=1.02x frame= 979 fps=4.0 q=-0.0 size= 5947425kB time=00:04:12.75 bitrate=192764.8kbits/s dup=1 drop=0 speed=1.02x frame= 982 fps=4.0 q=-0.0 size= 5965650kB time=00:04:13.50 bitrate=192783.5kbits/s dup=1 drop=0 speed=1.02x frame= 984 fps=4.0 q=-0.0 size= 5977800kB time=00:04:14.00 bitrate=192795.8kbits/s dup=1 drop=0 speed=1.02x frame= 987 fps=4.0 q=-0.0 size= 5996025kB time=00:04:14.75 bitrate=192814.3kbits/s dup=1 drop=0 speed=1.02x frame= 989 fps=4.0 q=-0.0 size= 6008175kB time=00:04:15.25 bitrate=192826.5kbits/s dup=1 drop=0 speed=1.02x frame= 992 fps=4.0 q=-0.0 size= 6026400kB time=00:04:16.00 bitrate=192844.8kbits/s dup=1 drop=0 speed=1.02x Past duration 0.982399 too large|
|2019-07-16 10:57:00|stderr|frame= 960 fps=4.0 q=-0.0 size= 5832000kB time=00:04:08.00 bitrate=192644.1kbits/s dup=1 drop=0 speed=1.02x Past duration 0.939461 too large|
|2019-07-16 10:56:59|stderr|frame= 931 fps=4.0 q=-0.0 size= 5655825kB time=00:04:00.75 bitrate=192450.8kbits/s dup=1 drop=0 speed=1.02x frame= 934 fps=4.0 q=-0.0 size= 5674050kB time=00:04:01.50 bitrate=192471.3kbits/s dup=1 drop=0 speed=1.02x frame= 937 fps=4.0 q=-0.0 size= 5692275kB time=00:04:02.25 bitrate=192491.7kbits/s dup=1 drop=0 speed=1.02x frame= 940 fps=4.0 q=-0.0 size= 5710500kB time=00:04:03.00 bitrate=192512.0kbits/s dup=1 drop=0 speed=1.02x frame= 942 fps=4.0 q=-0.0 size= 5722650kB time=00:04:03.50 bitrate=192525.5kbits/s dup=1 drop=0 speed=1.02x frame= 945 fps=4.0 q=-0.0 size= 5740875kB time=00:04:04.25 bitrate=192545.5kbits/s dup=1 drop=0 speed=1.02x frame= 947 fps=4.0 q=-0.0 size= 5753025kB time=00:04:04.75 bitrate=192558.9kbits/s dup=1 drop=0 speed=1.02x frame= 949 fps=4.0 q=-0.0 size= 5765175kB time=00:04:05.25 bitrate=192572.1kbits/s dup=1 drop=0 speed=1.02x frame= 952 fps=4.0 q=-0.0 size= 5783400kB time=00:04:06.00 bitrate=192591.9kbits/s dup=1 drop=0 speed=1.02x frame= 955 fps=4.0 q=-0.0 size= 5801625kB time=00:04:06.75 bitrate=192611.6kbits/s dup=1 drop=0 speed=1.02x frame= 957 fps=4.0 q=-0.0 size= 5813775kB time=00:04:07.25 bitrate=192624.7kbits/s dup=1 drop=0 speed=1.02x Past duration 0.978264 too large|
|2019-07-16 10:56:52|stderr|frame= 916 fps=4.0 q=-0.0 size= 5564700kB time=00:03:57.00 bitrate=192346.1kbits/s dup=1 drop=0 speed=1.02x frame= 919 fps=4.0 q=-0.0 size= 5582925kB time=00:03:57.75 bitrate=192367.3kbits/s dup=1 drop=0 speed=1.02x frame= 921 fps=4.0 q=-0.0 size= 5595075kB time=00:03:58.25 bitrate=192381.3kbits/s dup=1 drop=0 speed=1.02x frame= 924 fps=4.0 q=-0.0 size= 5613300kB time=00:03:59.00 bitrate=192402.3kbits/s dup=1 drop=0 speed=1.02x frame= 927 fps=4.0 q=-0.0 size= 5631525kB time=00:03:59.75 bitrate=192423.2kbits/s dup=1 drop=0 speed=1.02x frame= 929 fps=4.0 q=-0.0 size= 5643675kB time=00:04:00.25 bitrate=192437.0kbits/s dup=1 drop=0 speed=1.02x Past duration 0.983589 too large|
|2019-07-16 10:56:48|stderr|frame= 898 fps=4.0 q=-0.0 size= 5455350kB time=00:03:52.50 bitrate=192216.0kbits/s dup=1 drop=0 speed=1.03x frame= 900 fps=4.0 q=-0.0 size= 5467500kB time=00:03:53.00 bitrate=192230.7kbits/s dup=1 drop=0 speed=1.02x frame= 903 fps=4.0 q=-0.0 size= 5485725kB time=00:03:53.75 bitrate=192252.7kbits/s dup=1 drop=0 speed=1.03x frame= 905 fps=4.0 q=-0.0 size= 5497875kB time=00:03:54.25 bitrate=192267.2kbits/s dup=1 drop=0 speed=1.02x frame= 908 fps=4.0 q=-0.0 size= 5516100kB time=00:03:55.00 bitrate=192288.9kbits/s dup=1 drop=0 speed=1.02x frame= 911 fps=4.0 q=-0.0 size= 5534325kB time=00:03:55.75 bitrate=192310.5kbits/s dup=1 drop=0 speed=1.02x frame= 913 fps=4.0 q=-0.0 size= 5546475kB time=00:03:56.25 bitrate=192324.8kbits/s dup=1 drop=0 speed=1.02x Past duration 0.929771 too large|
|2019-07-16 10:56:44|stderr|frame= 883 fps=4.0 q=-0.0 size= 5364225kB time=00:03:48.75 bitrate=192103.7kbits/s dup=1 drop=0 speed=1.03x frame= 886 fps=4.0 q=-0.0 size= 5382450kB time=00:03:49.50 bitrate=192126.5kbits/s dup=1 drop=0 speed=1.03x frame= 888 fps=4.0 q=-0.0 size= 5394600kB time=00:03:50.00 bitrate=192141.6kbits/s dup=1 drop=0 speed=1.03x frame= 891 fps=4.0 q=-0.0 size= 5412825kB time=00:03:50.75 bitrate=192164.1kbits/s dup=1 drop=0 speed=1.03x frame= 893 fps=4.0 q=-0.0 size= 5424975kB time=00:03:51.25 bitrate=192179.0kbits/s dup=1 drop=0 speed=1.03x frame= 896 fps=4.0 q=-0.0 size= 5443200kB time=00:03:52.00 bitrate=192201.3kbits/s dup=1 drop=0 speed=1.03x Past duration 0.987907 too large|
|2019-07-16 10:56:40|stderr|frame= 881 fps=4.0 q=-0.0 size= 5352075kB time=00:03:48.25 bitrate=192088.5kbits/s dup=1 drop=0 speed=1.03x Past duration 0.947456 too large|
|2019-07-16 10:56:39|stderr|frame= 866 fps=4.0 q=-0.0 size= 5260950kB time=00:03:44.50 bitrate=191971.9kbits/s dup=1 drop=0 speed=1.03x frame= 868 fps=4.0 q=-0.0 size= 5273100kB time=00:03:45.00 bitrate=191987.7kbits/s dup=1 drop=0 speed=1.03x frame= 871 fps=4.0 q=-0.0 size= 5291325kB time=00:03:45.75 bitrate=192011.2kbits/s dup=1 drop=0 speed=1.03x frame= 873 fps=4.0 q=-0.0 size= 5303475kB time=00:03:46.25 bitrate=192026.8kbits/s dup=1 drop=0 speed=1.03x frame= 876 fps=4.0 q=-0.0 size= 5321700kB time=00:03:47.00 bitrate=192050.1kbits/s dup=1 drop=0 speed=1.03x frame= 879 fps=4.0 q=-0.0 size= 5339925kB time=00:03:47.75 bitrate=192073.2kbits/s dup=1 drop=0 speed=1.03x Past duration 0.992699 too large|
|2019-07-16 10:56:36|stderr|frame= 864 fps=4.0 q=-0.0 size= 5248800kB time=00:03:44.00 bitrate=191956.1kbits/s dup=1 drop=0 speed=1.03x Past duration 0.872932 too large|
|2019-07-16 10:56:35|stderr|frame= 851 fps=4.0 q=-0.0 size= 5169825kB time=00:03:40.75 bitrate=191851.4kbits/s dup=1 drop=0 speed=1.03x frame= 853 fps=4.0 q=-0.0 size= 5181975kB time=00:03:41.25 bitrate=191867.7kbits/s dup=1 drop=0 speed=1.03x frame= 856 fps=4.0 q=-0.0 size= 5200200kB time=00:03:42.00 bitrate=191892.1kbits/s dup=1 drop=0 speed=1.03x frame= 859 fps=4.0 q=-0.0 size= 5218425kB time=00:03:42.75 bitrate=191916.2kbits/s dup=1 drop=0 speed=1.03x frame= 861 fps=4.0 q=-0.0 size= 5230575kB time=00:03:43.25 bitrate=191932.2kbits/s dup=1 drop=0 speed=1.03x Past duration 0.982124 too large|
|2019-07-16 10:56:32|stderr|frame= 849 fps=4.0 q=-0.0 size= 5157675kB time=00:03:40.25 bitrate=191835.1kbits/s dup=1 drop=0 speed=1.03x Past duration 0.979988 too large|
|2019-07-16 10:56:31|stderr|frame= 834 fps=4.0 q=-0.0 size= 5066550kB time=00:03:36.50 bitrate=191709.8kbits/s dup=1 drop=0 speed=1.03x frame= 836 fps=4.0 q=-0.0 size= 5078700kB time=00:03:37.00 bitrate=191726.8kbits/s dup=1 drop=0 speed=1.03x frame= 839 fps=4.0 q=-0.0 size= 5096925kB time=00:03:37.75 bitrate=191752.1kbits/s dup=1 drop=0 speed=1.03x frame= 841 fps=4.0 q=-0.0 size= 5109075kB time=00:03:38.25 bitrate=191768.8kbits/s dup=1 drop=0 speed=1.03x frame= 844 fps=4.0 q=-0.0 size= 5127300kB time=00:03:39.00 bitrate=191793.8kbits/s dup=1 drop=0 speed=1.03x frame= 847 fps=4.0 q=-0.0 size= 5145525kB time=00:03:39.75 bitrate=191818.6kbits/s dup=1 drop=0 speed=1.03x Past duration 0.989555 too large|
|2019-07-16 10:56:27|stderr|frame= 818 fps=4.0 q=-0.0 size= 4969350kB time=00:03:32.50 bitrate=191571.4kbits/s dup=1 drop=0 speed=1.03x frame= 820 fps=4.0 q=-0.0 size= 4981500kB time=00:03:33.00 bitrate=191589.0kbits/s dup=1 drop=0 speed=1.03x frame= 823 fps=4.0 q=-0.0 size= 4999725kB time=00:03:33.75 bitrate=191615.2kbits/s dup=1 drop=0 speed=1.03x frame= 825 fps=4.0 q=-0.0 size= 5011875kB time=00:03:34.25 bitrate=191632.6kbits/s dup=1 drop=0 speed=1.03x frame= 828 fps=4.0 q=-0.0 size= 5030100kB time=00:03:35.00 bitrate=191658.5kbits/s dup=1 drop=0 speed=1.03x frame= 831 fps=4.0 q=-0.0 size= 5048325kB time=00:03:35.75 bitrate=191684.3kbits/s dup=1 drop=0 speed=1.03x Past duration 0.977547 too large|
|2019-07-16 10:56:24|stderr|Past duration 0.938042 too large|
|2019-07-16 10:56:23|stderr|frame= 786 fps=4.0 q=-0.0 size= 4774950kB time=00:03:24.50 bitrate=191278.2kbits/s dup=1 drop=0 speed=1.03x frame= 788 fps=4.0 q=-0.0 size= 4787100kB time=00:03:25.00 bitrate=191297.2kbits/s dup=1 drop=0 speed=1.03x frame= 791 fps=4.0 q=-0.0 size= 4805325kB time=00:03:25.75 bitrate=191325.5kbits/s dup=1 drop=0 speed=1.03x frame= 793 fps=4.0 q=-0.0 size= 4817475kB time=00:03:26.25 bitrate=191344.3kbits/s dup=1 drop=0 speed=1.03x frame= 796 fps=4.0 q=-0.0 size= 4835700kB time=00:03:27.00 bitrate=191372.2kbits/s dup=1 drop=0 speed=1.03x frame= 799 fps=4.0 q=-0.0 size= 4853925kB time=00:03:27.75 bitrate=191400.0kbits/s dup=1 drop=0 speed=1.03x frame= 802 fps=4.0 q=-0.0 size= 4872150kB time=00:03:28.50 bitrate=191427.6kbits/s dup=1 drop=0 speed=1.03x frame= 803 fps=4.0 q=-0.0 size= 4878225kB time=00:03:28.75 bitrate=191436.7kbits/s dup=1 drop=0 speed=1.03x frame= 806 fps=4.0 q=-0.0 size= 4896450kB time=00:03:29.50 bitrate=191464.0kbits/s dup=1 drop=0 speed=1.03x frame= 808 fps=4.0 q=-0.0 size= 4908600kB time=00:03:30.00 bitrate=191482.1kbits/s dup=1 drop=0 speed=1.03x frame= 811 fps=4.0 q=-0.0 size= 4926825kB time=00:03:30.75 bitrate=191509.1kbits/s dup=1 drop=0 speed=1.03x frame= 813 fps=4.0 q=-0.0 size= 4938975kB time=00:03:31.25 bitrate=191527.0kbits/s dup=1 drop=0 speed=1.03x frame= 815 fps=4.0 q=-0.0 size= 4951125kB time=00:03:31.75 bitrate=191544.8kbits/s dup=1 drop=0 speed=1.03x Past duration 0.912132 too large|
|2019-07-16 10:56:16|stderr|Past duration 0.963188 too large|
|2019-07-16 10:56:15|stderr|frame= 770 fps=4.0 q=-0.0 size= 4677750kB time=00:03:20.50 bitrate=191122.8kbits/s dup=1 drop=0 speed=1.03x frame= 772 fps=4.0 q=-0.0 size= 4689900kB time=00:03:21.00 bitrate=191142.6kbits/s dup=1 drop=0 speed=1.03x frame= 775 fps=4.0 q=-0.0 size= 4708125kB time=00:03:21.75 bitrate=191172.0kbits/s dup=1 drop=0 speed=1.03x frame= 777 fps=4.0 q=-0.0 size= 4720275kB time=00:03:22.25 bitrate=191191.6kbits/s dup=1 drop=0 speed=1.03x frame= 780 fps=4.0 q=-0.0 size= 4738500kB time=00:03:23.00 bitrate=191220.7kbits/s dup=1 drop=0 speed=1.03x frame= 783 fps=4.0 q=-0.0 size= 4756725kB time=00:03:23.75 bitrate=191249.5kbits/s dup=1 drop=0 speed=1.03x Past duration 0.906792 too large|
|2019-07-16 10:56:12|stderr|Past duration 0.998665 too large|
|2019-07-16 10:56:11|stderr|frame= 754 fps=4.0 q=-0.0 size= 4580550kB time=00:03:16.50 bitrate=190961.1kbits/s dup=1 drop=0 speed=1.03x frame= 756 fps=4.0 q=-0.0 size= 4592700kB time=00:03:17.00 bitrate=190981.7kbits/s dup=1 drop=0 speed=1.03x frame= 759 fps=4.0 q=-0.0 size= 4610925kB time=00:03:17.75 bitrate=191012.4kbits/s dup=1 drop=0 speed=1.03x frame= 761 fps=4.0 q=-0.0 size= 4623075kB time=00:03:18.25 bitrate=191032.7kbits/s dup=1 drop=0 speed=1.03x frame= 764 fps=4.0 q=-0.0 size= 4641300kB time=00:03:19.00 bitrate=191063.0kbits/s dup=1 drop=0 speed=1.03x frame= 767 fps=4.0 q=-0.0 size= 4659525kB time=00:03:19.75 bitrate=191093.0kbits/s dup=1 drop=0 speed=1.03x Past duration 0.981102 too large|
|2019-07-16 10:56:08|stderr|Past duration 0.948479 too large|
|2019-07-16 10:56:07|stderr|frame= 722 fps=4.0 q=-0.0 size= 4386150kB time=00:03:08.50 bitrate=190617.2kbits/s dup=1 drop=0 speed=1.03x frame= 724 fps=3.9 q=-0.0 size= 4398300kB time=00:03:09.00 bitrate=190639.5kbits/s dup=1 drop=0 speed=1.03x frame= 726 fps=3.9 q=-0.0 size= 4410450kB time=00:03:09.50 bitrate=190661.8kbits/s dup=1 drop=0 speed=1.03x frame= 729 fps=3.9 q=-0.0 size= 4428675kB time=00:03:10.25 bitrate=190694.9kbits/s dup=1 drop=0 speed=1.03x frame= 732 fps=3.9 q=-0.0 size= 4446900kB time=00:03:11.00 bitrate=190727.8kbits/s dup=1 drop=0 speed=1.03x frame= 735 fps=4.0 q=-0.0 size= 4465125kB time=00:03:11.75 bitrate=190760.4kbits/s dup=1 drop=0 speed=1.03x frame= 738 fps=4.0 q=-0.0 size= 4483350kB time=00:03:12.50 bitrate=190792.7kbits/s dup=1 drop=0 speed=1.03x frame= 739 fps=4.0 q=-0.0 size= 4489425kB time=00:03:12.75 bitrate=190803.5kbits/s dup=1 drop=0 speed=1.03x frame= 742 fps=4.0 q=-0.0 size= 4507650kB time=00:03:13.50 bitrate=190835.5kbits/s dup=1 drop=0 speed=1.03x frame= 744 fps=4.0 q=-0.0 size= 4519800kB time=00:03:14.00 bitrate=190856.7kbits/s dup=1 drop=0 speed=1.03x frame= 747 fps=4.0 q=-0.0 size= 4538025kB time=00:03:14.75 bitrate=190888.3kbits/s dup=1 drop=0 speed=1.03x frame= 749 fps=4.0 q=-0.0 size= 4550175kB time=00:03:15.25 bitrate=190909.3kbits/s dup=1 drop=0 speed=1.03x frame= 751 fps=4.0 q=-0.0 size= 4562325kB time=00:03:15.75 bitrate=190930.1kbits/s dup=1 drop=0 speed=1.03x Past duration 0.934532 too large|
|2019-07-16 10:56:00|stderr|Past duration 0.945198 too large|
Here is the current
