Yes, frigate is running as an unraid docker container, where the images/clips are saved.
HA is running on a raspi4.
The question is, if there is some kind of wrapper, to show the media-browser content which come from frigate, in a gallery card.
Anyone running frigate in docker on Windows?
Iām successfully running frigate 0.7 for couple of month actually with absolutely minimum configuration needed to run. It proved to be reliable after I solved all issues related to my Dahua cam streams. Now I want to move to latest version and use available features to make my setup even better
The point is Iām running it on a server with not HW acceleration and USB 2.0 meaning that each camera needs own CPU Core. Meaning I needed to dedicate 7 with at least more 2 to come. At the same time I need to get machine with Windows running 24/7 and I was wondering if I could use it for frigate with coral without need of getting another specifically for frigate? I now it would be better to use purely linux, but if it could use HW accel + coral and work lets say on two cores, that would be perfect.
I want to record clips of an object but not get notifications, how can I do that with your code?
I changed the last action to open a specific part of the HA app:
- action: URI
title: View Cameras
uri: '/lovelace-security/cameras'
Is there a way to run frigate on a window10? I had it as an add-on to my Hassio VM install but it eats up all my storageā¦
I was thinking of running it on my windows10 where I have BlueIris installed. Was going to have a Coral mini pcie installed on there.
You donāt want to get notifications from where? HA? Just donāt include that camera label in your automation.yml
which provides all the notification automation settings.
Yeah Iāve started using the automation that @mate provided as it covers all cameras with a template but I donāt know how to exclude a specific object from a specific camera with it.
I was hoping I could just put objects: in the MQTT camera config to only publish messages for filtered objects but thatās not supported.
Yeah you just need to specify the camera you want. Here is an example from his docs that contains three conditions before an action is triggered. You can use as many (or as few) conditions as you want. You definitely need to use the camera
condition so you will only get notifications on the cameras you want and can ignore the ones you donāt.
- alias: Notify for dogs in the front with a high top score
platform: mqtt
topic: frigate/events
condition:
- "{{ trigger.payload_json['after']['label'] == 'dog' }}"
- "{{ trigger.payload_json['after']['camera'] == 'front' }}"
- "{{ trigger.payload_json['after']['top_score'] > 0.98 }}"
- service: notify.mobile_app_pixel_3
data_template:
message: 'High confidence dog detection.'
image: "https://url.com/api/frigate/notifications/{{trigger.payload_json['after']['id']}}/thumbnail.jpg"
tag: "{{trigger.payload_json['after']['id']}}"
Yes i got it working but still in the early stages (Iām new to docker). Had issues figuring out the directories to use under volumes. Now i canāt figure out how to find the IP for the GUI interface
Need to also add the pcie coral afterwardsā¦
Once step at a timeā¦
the ip from local docker must be something like
127.0.0.1:5000
this settings worked for me with google coral
devices:
- /dev/bus/usb:/dev/bus/usb
So pcie falls under usb? got the GUI to show up. Now looking into push notificationsā¦I donāt have the coral pcie yet (just ordered it) but it will most definetly need to put into action since my cpu/ram are hitting 80+%
Can you please share more details about your setup?
Anyone running a docker in win10, how did you get the ffmpeg to work in docker? I have an intel i7 so I used this:
ffmpeg:
hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- /dev/dri/renderD128
- -hwaccel_output_format
- yuv420p
but whenever I add this it makes my videos go green.
the screenshot above was from last night. I tested custom created models with face recognition. And there was not a real camera pluged in. For testing porpuse i faked a local rtsp server which plays a video i created from people images from the front cam. So i cant tell you a lot about load on my windows 10 pc.
But i can track the load on my unraid server with running shinobi for face recoccnition and frigate for everything else.
Here are some screens from the last 14 days. The high cpu load from frigate may be missleading. Im running a dashboard here with the live view from the debug cam, which produce a lot more cpu load as normally.
I have only one rtsp cam. The 640px stream for detection stuff and the 4k stream for recording.
Running on
AMD Ryzen 7 3700X 8-Core @ 3600 MHz, 64gb ram,
Unraid Nvidia Version: 6.8.3
Shinobi use the Nvidia RTX2060 for encoding, Frigate a Coral USB Stick
Really excited to try this out but having trouble at the first step. Trying to install the add on and get the following error -
1-03-03 21:16:46 ERROR (MainThread) [supervisor.jobs] Unhandled exception: 'NoneType' object has no attribute 'is_file'
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 100, in wrapper
return await self._method(*args, **kwargs)
File "/usr/src/supervisor/supervisor/addons/__init__.py", line 182, in install
await addon.instance.install(store.version, store.image)
File "/usr/src/supervisor/supervisor/utils/__init__.py", line 32, in wrap_api
return await method(api, *args, **kwargs)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/supervisor/supervisor/docker/addon.py", line 491, in _install
self._build(version)
File "/usr/src/supervisor/supervisor/docker/addon.py", line 500, in _build
build_env = AddonBuild(self.coresys, self.addon)
File "/usr/src/supervisor/supervisor/addons/build.py", line 32, in __init__
super().__init__(
File "/usr/src/supervisor/supervisor/utils/common.py", line 59, in __init__
self.read_data()
File "/usr/src/supervisor/supervisor/utils/common.py", line 72, in read_data
if self._file.is_file():
AttributeError: 'NoneType' object has no attribute 'is_file'
Anyone come across this before?
This is my docker-compose file:
version: '3.9'
services:
frigate:
container_name: frigate
privileged: true # this may not be necessary for all setups
restart: unless-stopped
image: blakeblackshear/frigate:stable-amd64
devices:
- /dev/dri/renderD128 # for intel hwaccel, needs to be updated for your hardware
volumes:
- /etc/localtime:/etc/localtime:ro
- ./frigate/config:/config
- ./frigate/clips:/media/frigate/clips
- /storage01/frigate/recordings:/media/frigate/recordings
- type: tmpfs
target: /tmp/cache
tmpfs:
ports:
- '5000:5000'
- '1935:1935' # RTMP feeds
environment:
FRIGATE_RTSP_PASSWORD: 'password'
depends_on:
- ffmpeg
ffmpeg:
image: jrottenberg/ffmpeg:3.3
But I canāt get the ffmpeg to workā¦
Getting: ffmpeg process is not running
How do I make ffmpeg work in win10 docker?
Under cli it seems as if ffmpeg is there:
# ffmpeg
ffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 9 (Ubuntu 9.3.0-17ubuntu1~20.04)
configuration: --disable-debug --disable-doc --disable-ffplay --enable-shared --enable-avresample --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-gpl --enable-libfreetype --enable-libvidstab --enable-libmfx --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libxcb --enable-libx265 --enable-libxvid --enable-libx264 --enable-nonfree --enable-openssl --enable-libfdk_aac --enable-postproc --enable-small --enable-version3 --enable-libzmq --extra-libs=-ldl --prefix=/opt/ffmpeg --enable-libopenjpeg --enable-libkvazaar --enable-libaom --extra-libs=-lpthread --enable-vaapi --extra-cflags=-I/opt/ffmpeg/include --extra-ldflags=-L/opt/ffmpeg/lib
libavutil 56. 51.100 / 56. 51.100
libavcodec 58. 91.100 / 58. 91.100
libavformat 58. 45.100 / 58. 45.100
libavdevice 58. 10.100 / 58. 10.100
libavfilter 7. 85.100 / 7. 85.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 7.100 / 5. 7.100
libswresample 3. 7.100 / 3. 7.100
libpostproc 55. 7.100 / 55. 7.100
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
This is my config.yml (I have an intel <10 gen):
ffmpeg:
hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- yuv420p
I used this Dockerfile: https://raw.githubusercontent.com/alfg/docker-ffmpeg/master/Dockerfile
I have a silly question:
there is a way to run frigate directly on a Coral Dev board or send the data to him?
Iām trying to get the coral usb but is out-of-stock in many store,
care to share your flow? I want to send a notification using pushoverā¦
Just tried to install also and Iām having the same issue aswell.
Thank you!!! Worked like a charm <3
