Did you add any cameras to your config?
Then you are running an old version.
I suspected this might be the case. Will update and see how things go.
Paul, sorry I am trying to learn. I have installed ubuntu, docker, portainer etc. And I am stuckā¦
I have:
Gives me:
I have added my frigate.yml file in /etc/frigate/config/frigate.yml directory.
I briefly get container starting with published port 5000:5000 but then it disappears?
What am I doing wrong? Well can also ask the other way around: what am I doing right I got so far
Iād click the Logs
button in portainer to see why the container is failing to start.
Hi!
What is wrong with this?
detectors:
coral:
type: edgetpu
device: usb
mqtt:
host: 192.168.1.60
port: 1883
topic_prefix: frigate
client_id: frigate
user: xxx
password: xxx
cameras:
eteinen:
ffmpeg:
inputs:
- path: rtsp://xxi:[email protected]:554/stream1
roles:
- detect
width: 1920
height: 1080
fps: 5
snapshots:
enabled: true
bounding_box: true
takapiha:
ffmpeg:
inputs:
- path: rtsp://xx:[email protected]:554/Streaming/Channels/1
roles:
- detect
- rtmp
- clips
width: 1920
height: 1080
fps: 5
clips:
enabled: true
pre_capture: 5
post_capture: 5
objects:
- person
- animal
snapshots:
enabled: true
bounding_box: true
What Iād like to achieve is object detection persons and animals (at first). Person detection is working and I am getting events but every time I am trying to anything to the yml file its give me an error like:
* Starting nginx nginx
...done.
Error parsing config: extra keys not allowed @ data['cameras']['takapiha']['clips']['snapshots']
I am running HA with Intel Nuc docker and Frigate has been installed from HACS.
Check your indentation and match it up with the example config in the docs (https://blakeblackshear.github.io/frigate/configuration/cameras#full-example). Your snapshots:
section for the takapiha
camera needs to be moved left by two spaces so that it lines up with clips:
I just submitted a pull request to the HassOS repo to build in the gasket/apex drivers as modules. I have it running on my test machine, so hopefully they will incorporate it soon and I can put it on my main machine.
Thxā¦ Yeapā¦ that is something what I should check at first (indentation)ā¦
Anybody have stepbystep instructions for more detailed object detection than just a person?
The docs are your friend again here. Look at the COCO label map for the model that Frigate uses. That will give you a list of all of the trained objects that can be detected. Then, just add that label to your configuration (as you did with āanimalā - though āanimalā is not a valid object in the label map).
Thxā¦ Just need a guidance maybe also because some kind of language barriorā¦
Anywayā¦ how I clean events manually if not needed anymore after test?
Hi, How would I be able to also view the clips?
I have in config:
clips:
# Optional: Maximum length of time to retain video during long events. (default: shown below)
# NOTE: If an object is being tracked for longer than this amount of time, the cache
# will begin to expire and the resulting clip will be the last x seconds of the event.
max_seconds: 300
# Optional: size of tmpfs mount to create for cache files (default: not set)
# mount -t tmpfs -o size={tmpfs_cache_size} tmpfs /tmp/cache
# NOTICE: Addon users must have Protection mode disabled for the addon when using this setting.
# Also, if you have mounted a tmpfs volume through docker, this value should not be set in your config.
tmpfs_cache_size: 256m
# Optional: Retention settings for clips (default: shown below)
retain:
# Required: Default retention days (default: shown below)
default: 100
# Optional: Per object retention days
objects:
person: 150
I see:
I can go through my images, they are saved, but no clipsā¦?
Have you set clips role for the camera?
cameras:
back:
ffmpeg:
inputs:
- path: rtsp://viewer:{FRIGATE_RTSP_PASSWORD}@10.0.10.10:554/live
roles:
- clips
Have tried this, thanks will let know.
Another question. I added a 3rd cam and now I have:
Fatal Python error: Bus error
According to documentaion I need to increase shm size according to https://blakeblackshear.github.io/frigate/installation#calculating-shm-size. But how and where can I do this when I am using portainer to start Frigate?
I calculated the shm:
total is 54ā¦ was 64 and I changed in the docker config file to 96 with:
EDIT (128 also not working)
But still it doesnt workā¦
What am I doing wrong now?
Whats weird, the 1st and 2nd cam seem to keep ruuning (can see the time and live image). Clips is off for the 3rd camā¦ but taht stops.
EDIT: itās a matter of timeā¦ if motion is on the other cam it also stopsā¦
The error:
frigate.app INFO : Capture process started for parking: 70
Thread 0x00007fcd6e6f2700 (most recent call first):
File "/usr/lib/python3.8/threading.py", line 302 in wait
File "/usr/lib/python3.8/multiprocessing/queues.py", line 227 in _feed
File "/usr/lib/python3.8/threading.py", line 870 in run
File "/usr/lib/python3.8/threading.py", line 932 in _bootstrap_inner
File "/usr/lib/python3.8/threading.py", line 890 in _bootstrap
Current thread 0x00007fcd70ef3700 (most recent call first):
File "/opt/frigate/frigate/video.py", line 117 in capture_frames
File "/opt/frigate/frigate/video.py", line 231 in run
Thread 0x00007fcd736f4700 (most recent call first):
File "/opt/frigate/frigate/video.py", line 205 in run
Thread 0x00007fcd73ef5700 (most recent call first):
File "/opt/frigate/frigate/log.py", line 71 in run
Thread 0x00007fcd878eb740 (most recent call first):
File "/usr/lib/python3.8/threading.py", line 1027 in _wait_for_tstate_lock
File "/usr/lib/python3.8/threading.py", line 1011 in join
File "/opt/frigate/frigate/video.py", line 245 in capture_camera
File "/usr/lib/python3.8/multiprocessing/process.py", line 108 in run
File "/usr/lib/python3.8/multiprocessing/process.py", line 315 in _bootstrap
File "/usr/lib/python3.8/multiprocessing/popen_fork.py", line 75 in _launch
File "/usr/lib/python3.8/multiprocessing/popen_fork.py", line 19 in __init__
File "/usr/lib/python3.8/multiprocessing/context.py", line 277 in _Popen
File "/usr/lib/python3.8/multiprocessing/context.py", line 224 in _Popen
File "/usr/lib/python3.8/multiprocessing/process.py", line 121 in start
File "/opt/frigate/frigate/app.py", line 182 in start_camera_capture_processes
File "/opt/frigate/frigate/app.py", line 228 in start
File "/opt/frigate/frigate/__main__.py", line 15 in <module>
File "/usr/lib/python3.8/runpy.py", line 87 in _run_code
File "/usr/lib/python3.8/runpy.py", line 194 in _run_module_as_main
EDIT: If there is no motion all 3 cams keep workingā¦ as soon as there is was/some motion it stops.
Hello!
So here it goes.
Running Home Assistant OS 5.12, core-2021.3.2, supervisor-2021.03.4, on Intel NUC.
I read about frigate and said to give it a try.
First I made in Unifi 2 rules for port forwarding 5000 and 1935 from anywhere to IP of NUC only TCP.
Then continuing with installation, I read the part that says āNote that HassOS Addons and custom components are different things. If you are already running Frigate with Docker directly, you do not need the Addon since the Addon would run another instance of Frigate."
So I thought I would just need to install custom component from HACS and nothing else.
Installed it in Hacs but then couldnāt add the integration:
Configuration->integrations->+add integration->Frigate-> used āhttp://ccab4aaf-frigate:5000ā and got message āUnable to connect to Frigate.ā
Question 1
Do I really need to add Frigate NVR from Supervisore->Add-on Store? If not, why I get this message? What needs to be configured and where?
Then, I tried the other way. Installed Frigate NVR from Supervisore->Add-on Store, in configuration I let 1935 and 5000 as is, created frigate.yml in config folder and entered:
mqtt:
host: IP of NUC
user: my mqtt user
password: my mqtt password
cameras:
outdoor:
ffmpeg:
inputs:
- path: rtsp://<username>:<password>@<address>:<port>/Streaming/Channels/102
roles:
- detect
- rtmp
width: 640
height: 360
fps: 5
Then I get the below log when I start the add-on:
...done.
frigate.app INFO : Creating directory: /tmp/cache
Starting migrations
peewee_migrate INFO : Starting migrations
There is nothing to migrate
peewee_migrate INFO : There is nothing to migrate
frigate.app INFO : Camera processor started for outdoor: 38
frigate.app INFO : Capture process started for outdoor: 40
detector.coral INFO : Starting detection process: 36
frigate.edgetpu INFO : Attempting to load TPU as usb
frigate.edgetpu INFO : No EdgeTPU detected.
Process detector:coral:
File "/usr/local/lib/python3.8/dist-packages/tflite_runtime/interpreter.py", line 152, in load_delegate
delegate = Delegate(library, options)
File "/usr/local/lib/python3.8/dist-packages/tflite_runtime/interpreter.py", line 111, in __init__
raise ValueError(capture.message)
ValueError
File "/usr/lib/python3.8/multiprocessing/process.py", line 315, in _bootstrap
self.run()
File "/usr/lib/python3.8/multiprocessing/process.py", line 108, in run
self._target(*self._args, **self._kwargs)
File "/opt/frigate/frigate/edgetpu.py", line 124, in run_detector
object_detector = LocalObjectDetector(tf_device=tf_device, num_threads=num_threads)
File "/opt/frigate/frigate/edgetpu.py", line 63, in __init__
edge_tpu_delegate = load_delegate('libedgetpu.so.1.0', device_config)
File "/usr/local/lib/python3.8/dist-packages/tflite_runtime/interpreter.py", line 154, in load_delegate
raise ValueError('Failed to load delegate from {}\n{}'.format(
ValueError: Failed to load delegate from libedgetpu.so.1.0
frigate.mqtt INFO : MQTT connected
frigate.watchdog INFO : Detection appears to have stopped. Exiting frigate...
frigate.app INFO : Stopping...
frigate.events INFO : Exiting event processor...
frigate.record INFO : Exiting recording maintenance...
frigate.object_processing INFO : Exiting object processor...
frigate.events INFO : Exiting event cleanup...
frigate.watchdog INFO : Exiting watchdog...
Question 2
What am I missing?
pardon my noobynesā¦
The error youāre seeing in the logs is due to the fact that you donāt have a Coral device and you havenāt defined a CPU detector in the config file. Check the docs.
Pulled the latest image and am getting a couple errors in the logs, not sure where to look for the issue.
detector.coral INFO : Starting detection process: 42
frigate.app INFO : Camera processor started for porch: 45
frigate.app INFO : Capture process started for porch: 46
frigate.edgetpu INFO : TPU found
frigate.video INFO : porch: ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have different structures
frigate.video INFO : porch: ffmpeg process is not running. exiting capture thread...
ffmpeg.porch.detect ERROR : [h264_v4l2m2m @ 0x564653183b80] Could not find a valid device
ffmpeg.porch.detect ERROR : [h264_v4l2m2m @ 0x564653183b80] can't configure decoder
ffmpeg.porch.detect ERROR : Error while opening decoder for input stream #0:1 : Invalid argument
These errors repeat in my log and my web interface is showing green background in the camera view.
The RTMP stream I am using works in vlc.
I am using a Reolink RLC-410 camera.
Thanks for the great work!
Check the docs: https://blakeblackshear.github.io/frigate/configuration/cameras#reolink-410520-possibly-others
Maybe a stupid question perhaps but. ā¦
How do I allow Frigate to other users through Home assistant app?
It doesnāt show up when my wife opens her ha app.
