retained mqtt message?
Oh baby! Loving the new Birdseye feature!
Here is my full working config for reference. Note that I did not do full time recording before or after 2x. I use my Ubiquiti UDMP for long term storage of recordings. I have six cameras being pulled into Frigate but just have the config for one in the code below. I use a NUC with Corals.
detectors:
coral_pci:
type: edgetpu
device: pci
coral_usb:
type: edgetpu
device: usb
mqtt:
host: core-mosquitto
port: 1883
topic_prefix: frigate
client_id: frigate
user: XXXXXXX
password: XXXXXXX
birdseye:
enabled: True
width: 1280
height: 720
quality: 8
mode: objects
ffmpeg:
global_args:
-hide_banner
-loglevel warning
input_args:
-avoid_negative_ts make_zero
-fflags +genpts+discardcorrupt
-rtsp_transport tcp
-stimeout 5000000
-use_wallclock_as_timestamps 1
output_args:
detect:
-f rawvideo
-pix_fmt yuv420p
record:
-f segment
-segment_time 60
-segment_format mp4
-reset_timestamps 1
-strftime 1 -c copy -an
rtmp:
-c copy
-f flv
hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- /dev/dri/renderD128
- -hwaccel_output_format
- yuv420p
record:
enabled: true
retain_days: 0
events:
retain:
default: 30
snapshots:
retain:
default: 10
objects:
person: 15
cameras:
####FRONT DOOR####
front_door:
ffmpeg:
inputs:
- path: rtsp://XXXXX
roles:
- detect
- record
- rtmp
detect:
width: 1600
height: 1200
fps: 10
motion:
mask:
- 0,411,0,720,670,664,1242,658,1298,559,1600,540,1600,0,0,0
zones:
patio:
coordinates: 1600,1200,1264,934,1285,743,1086,709,966,743,737,763,390,803,0,1116,0,1200
snapshots:
enabled: true
bounding_box: true
crop: false
timestamp: false
New image pushed to docker (stable-amd64) yesterday, container now cannot start. Iām looking through docs saw there were some breaking changes so I made the adjustments in my config. Still no go.
Looking at the container logs I see its having issues hitting run.sh
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
ifelse: fatal: unable to exec /run.sh: No such file or directory
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Iām running it with docker-compose on a separate box from my HA. It had been running successfully for months. Absolutely love this project and greatly appreciate the work and effort that goes into it.
I cant watch clips. On two differwnt HA servers and through app and webbrowser pwa mobile. After 2.0 update. Was working perfectly before update
I had the same error, for me a HA restart fixed it.
You probably have a warning message in your logs about not having the record role assigned to an input with recording enabled. You need add record where you removed clips.
Top of config:
detectors:
coral_pci:
type: edgetpu
device: pci
ffmpeg:
# Optional: global ffmpeg args (default: shown below)
global_args: -hide_banner -loglevel warning
# Optional: global hwaccel args (default: shown below)
# NOTE: See hardware acceleration docs for your specific device
hwaccel_args:
- -hwaccel
- qsv
- -qsv_device
# Optional: global input args (default: shown below)
input_args: -avoid_negative_ts make_zero -fflags +genpts+discardcorrupt -rtsp_transport tcp -stimeout 5000000 -use_wallclock_as_timestamps 1
# Optional: global output args
output_args:
# Optional: output args for detect streams (default: shown below)
detect: -f rawvideo -pix_fmt yuv420p
# Optional: output args for record streams (default: shown below)
#longloading-record: -f segment -segment_time 60 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c:v libx264 -an
#longloading-clips: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c:v libx264 -an
record: -f segment -segment_time 60 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy -an
# Optional: output args for clips streams (default: shown below)
#clips: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy -an
and Each cam have same setup on one server 11cams other server 11cams
CAM_garaz:
ffmpeg:
inputs:
- path: rtsp://xxx:xxxx@192xxxx:554/cam/realmonitor?channel=1&subtype=0&authbasic=xxxx
roles:
- detect
#- clips
zones:
zone_0:
coordinates: 0,1080,1388,1080,1920,1080,1920,660,1792,476,1412,110,581,47,309,161,0,386
detect:
enabled: True
max_disappeared: 25
width: 1920
height: 1080
fps: 5
#best_image_timeout: 60
record:
enabled: True
retain_days: 0
events:
post_capture: 10
pre_capture: 5
objects:
- person
retain:
default: 5
rtmp:
enabled: False
snapshots:
enabled: True
timestamp: False
bounding_box: True
crop: False
retain:
default: 5
#objects:
#person: 15
mqtt:
enabled: False
timestamp: True
bounding_box: True
crop: True
height: 270
objects:
track:
- person
filters:
person:
min_area: 1000
max_area: 100000
min_score: 0.5
threshold: 0.77
same after restart
Some other settings are broking on update?
[2021-10-08 07:28:42] frigate.video INFO : CAM1: ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have different structures
[2021-10-08 07:28:42] frigate.video INFO : CAM1: ffmpeg process is not running. exiting capture thread...
[2021-10-08 07:28:52] watchdog.CAM1 ERROR : FFMPEG process crashed unexpectedly for CAM1.
[2021-10-08 07:28:52] watchdog.CAM1 ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
[2021-10-08 07:28:52] watchdog.CAM1 ERROR : You may have invalid args defined for this camera.
Sorry, I also update and got errosā¦ and I donāt know where to startā¦
cameras -> schuurachter -> ffmpeg -> inputs -> 0 -> roles -> 1
value is not a valid enumeration member; permitted: 'record', 'rtmp', 'detect' (type=type_error.enum; enum_values=[<CameraRoleEnum.record: 'record'>, <CameraRoleEnum.rtmp: 'rtmp'>, <CameraRoleEnum.detect: 'detect'>])
cameras -> schuurachter -> clips
extra fields not permitted (type=value_error.extra)
cameras -> schuurachter -> fps
cameras -> schuurachter -> height
cameras -> schuurachter -> width
cameras -> parkeerplaats -> ffmpeg -> inputs -> 0 -> roles -> 1
cameras -> parkeerplaats -> clips
cameras -> parkeerplaats -> fps
cameras -> parkeerplaats -> height
cameras -> parkeerplaats -> width
cameras -> voortuin -> ffmpeg -> inputs -> 0 -> roles -> 1
cameras -> voortuin -> clips
cameras -> voortuin -> fps
cameras -> voortuin -> height
cameras -> voortuin -> width
cameras -> terras -> ffmpeg -> inputs -> 0 -> roles -> 1
cameras -> terras -> clips
cameras -> terras -> fps
cameras -> terras -> height
cameras -> terras -> width
[cmd] python3 exited 1
those are easy, you need to rewrite your config, move as per documentation. I was also shocked at first but after 30minutes all fixed.
Remove all mention on clips.
Add record True with retention false (if you donāt use 24/7 recording) and move your settings frrom clips to record
clips is no longer a valid role and should be removed
FPS not needed
This is an example of 1-5 cams:
cameras:
# FRONT Camera ########################################################################################################
voordeur:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]:554/Streaming/Channels/101/
roles:
- detect
- clips
# - rtmp
width: 2560
height: 1440
fps: 6
snapshots:
enabled: true
crop: false
bounding_box: True
objects:
track:
- person
- dog
- cat
motion:
mask:
- '1090,81,1216,0,1382,34,1532,99,1518,259,1426,363,1123,247'
- '1766,498,1753,669,1778,722,1829,773,1863,825,1906,884,1924,955,1953,1065,2237,1169,2255,1128,2295,1046,2338,946,2378,841,2410,743,2215,647,2190,582,2138,512,2010,402,1859,351'
clips:
# Required: enables clips for the camera (default: shown below)
# This value can be set via MQTT and will be updated in startup based on retained value
enabled: True
# Optional: Number of seconds before the event to include in the clips (default: shown below)
pre_capture: 2
# Optional: Number of seconds after the event to include in the clips (default: shown below)
post_capture: 2
# Optional: Objects to save clips for. (default: all tracked objects)
objects:
- person
- dog
- cat
# Optional: Restrict clips to objects that entered any of the listed zones (default: no required zones)
required_zones: []
# Optional: Camera override for retention settings (default: global values)
retain:
# Required: Default retention days (default: shown below)
default: 10
# Optional: Per object retention days
objects:
person: 200
dog: 20
cat: 200
What should I do with the āclipsā section then?
Frigate Integration will not connect after update and followed the new config based on item 3 in new document.
`Frigate
URL you use to access Frigate (ie. http://frigate:5000/)
If you are using HassOS with the addon, the URL should be http://ccab4aaf-frigate:5000/
Home Assistant needs access to port 5000 (api) and 1935 (rtmp) for all features.
The integration will setup sensors, cameras, and media browser functionality.
Sensors:
Stats to monitor frigate performance
Object counts for all zones and cameras
Cameras:
Cameras for image of the last detected object for each camera
Camera entities with stream support (requires RTMP)
Media Browser:
Rich UI with thumbnails for browsing event clips
Rich UI for browsing 24/7 recordings by month, day, camera, time
API:
Notification API with public facing endpoints for images in notifications
Failed to connect
URL
New Config.yml Frigate
URL you use to access Frigate (ie. `http://frigate:5000/`)
If you are using HassOS with the addon, the URL should be `http://ccab4aaf-frigate:5000/`
Sensors:
* Stats to monitor frigate performance
* Object counts for all zones and cameras
Cameras:
* Cameras for image of the last detected object for each camera
* Camera entities with stream support (requires RTMP)
Media Browser:
* Rich UI with thumbnails for browsing event clips
* Rich UI for browsing 24/7 recordings by month, day, camera, time
API:
* Notification API with public facing endpoints for images in notifications
Failed to connect
URL
SUBMIT
mqtt:
host: 192.168.0.74
client_id: frigate
user: mikey
password: xxxxxx
detectors:
cpu1:
type: cpu
num_threads: 3
cameras:
camera1:front_driveway:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]:554/h264Preview_01_sub
roles:
- detect
width: 1280
height: 720
Any idea where i am going wrong as i am trying to setup agin in HASSO
CAM_obyvak:
ffmpeg:
inputs:
- path: rtsp://xxxx:xxxx@xxxx:554/cam/realmonitor?channel=1&subtype=0&authbasic=xxxxx
roles:
- detect
zones:
zone_0:
coordinates: 0,1080,1429,1080,1855,583,1876,490,1309,380,1333,0,0,0
detect:
enabled: True
max_disappeared: 25
width: 1920
height: 1080
fps: 5
record:
enabled: False
retain_days: 0
events:
post_capture: 10
pre_capture: 5
objects:
- person
retain:
default: 5
rtmp:
enabled: False
snapshots:
enabled: True
timestamp: False
bounding_box: True
crop: False
retain:
default: 5
#objects:
#person: 15
mqtt:
enabled: False
timestamp: True
bounding_box: True
crop: True
height: 270
objects:
track:
- person
filters:
person:
min_area: 1000
max_area: 100000
min_score: 0.5
threshold: 0.77
No 24/7 recording
I totally do not get this:
cameras:
voordeur:
ffmpeg:
inputs:
roles:
- detect
#- clips
# - rtmp
detect:
width: 2560
height: 1440
# fps: 6
snapshots:
enabled: true
crop: false
bounding_box: True
objects:
track:
- person
- dog
- cat
motion:
mask:
# clips:
# enabled: True
# pre_capture: 2
# post_capture: 2
# objects:
# - person
# - dog
# - cat
# required_zones: []
# retain:
# default: 10
# objects:
# person: 200
# dog: 20
# cat: 200
with this errors:
[services.d] done.
[2021-10-08 16:15:28] frigate.app INFO : Starting Frigate (0.9.1-800f33e)
Error parsing config: 26 validation errors for FrigateConfig
ffmpeg -> output_args -> clips
cameras -> voordeur -> ffmpeg -> inputs -> 0 -> roles -> 1
cameras -> voordeur -> clips
cameras -> voordeur -> fps
cameras -> voordeur -> height
cameras -> voordeur -> width
whatās wrong there?
did you save the config before restart? maybe save and restart again
Its still saying you have clips as a role and heig tht/width/fps under FFMPEG section but above looks correct so I thinking it not saved before you try restart
I really didā¦ Not
Another question. How do I delete all recordings? and database?
If its a one time thing just delete the db file in config and remove all the media files?
