Local Tuya and Contact Sensor
i have configured the latest local tuya integration.
All works fine and the Device was successfully imported to Homeassistant.
I use a Contact Sensor (Model PB-69W-1).
Now, when the device is offline (i think it’s the deepsleep mode) the device is marked as unavailable in HomeAssistant. If the Windows was opened, then after 5 Seconds the Device will be online an set the status open. After 10 Seconds, the Sensor is unavailable again in HA. I can’t ping the Device in this status.
Is there a way to disable the “not available” Status?
Regards
Herbert.
I have the same issue. Am using model 19EWT (super cheap aliexpress). I honestly didn’t really mean to buy a wifi one, but whatever.
It shows the correct data in the regular Tuya integration (open, closed - whatever the last status was). In the LocalTuya integration it goes to “unavailable” after 10 seconds or so as mentioned by Herbert.
I could imagine creating a helper that just shows the most recent opened or closed status and using that as a proxy, but it just doesn’t seem ideal. Would love to know if there is a better way I can configure this so that it doesn’t go unavailable.
Anyone with advice about this? Grateful in advance.
