Have just got 2 more RGB bulbs, I can use smart life app to control it.
Added through local tuya, it’s only showing the states but not able to control it at all…
turned out I have log returned it’s not able to connect…
Don’t really understand what is happening… can anyone help?
This error originated from a custom integration.
Logger: custom_components.localtuya.common
Source: custom_components/localtuya/pytuya/init.py:637
Integration: LocalTuya (documentation, issues)
First occurred: 4:23:25 PM (314 occurrences)
Last logged: 9:36:25 PM
[683…957] Connect to 192.xxx.xx.xxx failed
File “/config/custom_components/localtuya/common.py”, line 139, in _make_connection
self._interface = await pytuya.connect(
File “/config/custom_components/localtuya/pytuya/init.py”, line 637, in connect
_, protocol = await loop.create_connection(
File “/usr/local/lib/python3.9/asyncio/base_events.py”, line 1056, in create_connection
raise exceptions[0]
File “/usr/local/lib/python3.9/asyncio/base_events.py”, line 1041, in create_connection
sock = await self._connect_sock(
File “/usr/local/lib/python3.9/asyncio/base_events.py”, line 955, in _connect_sock
await self.sock_connect(sock, address)
File “/usr/local/lib/python3.9/asyncio/selector_events.py”, line 502, in sock_connect
return await fut
File “/usr/local/lib/python3.9/asyncio/selector_events.py”, line 537, in _sock_connect_cb
raise OSError(err, f’Connect call failed {address}’)
OSError: [Errno 113] Connect call failed ('192.xxx.xx.xxx", 6668)
