I went through the different installations - adding to ESP home modifying the code and uploading and chromium installation. Both methods do not let the device to respond by playing the media URL.
I have the wake word processing on the device and not home assistant. Once I say the wake word the light changes to slow pulsing blue and then changes into fast flashing blue. The command executes but does not play the response URL.
My Home assistant config is
- Core - 2025.3.4
- Supervisor - 2025.03.3
- Operating System - 15.0
- Frontend - 20250306.0
The M5stack version is 25.2.1
After I issue a command the device shows playing but nothing happens, see below:
[D][micro_wake_word:195]: State changed from STARTING_MICROPHONE to DETECTING_WAKE_WORD
[I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[D][esp32.preferences:114]: Saving 1 preferences to flash…
[D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[D][switch:016]: ‘Use listen light’ Turning OFF.
[D][switch:055]: ‘Use listen light’: Sending state OFF
[D][light:036]: ‘M5Stack Atom Echo a13ffc’ Setting:
[D][light:047]: State: OFF
[D][switch:012]: ‘Use listen light’ Turning ON.
[D][switch:055]: ‘Use listen light’: Sending state ON
[D][light:047]: State: ON
[D][light:051]: Brightness: 60%
[D][light:059]: Red: 100%, Green: 89%, Blue: 71%
[D][micro_wake_word:162]: The ‘Okay Nabu’ model sliding average probability is 0.976 and most recent probability is 1.000
[D][micro_wake_word:123]: Wake Word ‘Okay Nabu’ Detected
[D][micro_wake_word:195]: State changed from DETECTING_WAKE_WORD to STOP_MICROPHONE
[D][micro_wake_word:129]: Stopping Microphone
[D][micro_wake_word:195]: State changed from STOP_MICROPHONE to STOPPING_MICROPHONE
[D][esp-idf:000]: I (90158) I2S: DMA queue destroyed
[D][micro_wake_word:195]: State changed from STOPPING_MICROPHONE to IDLE
[D][voice_assistant:506]: State changed from IDLE to START_MICROPHONE
[D][voice_assistant:512]: Desired state set to START_PIPELINE
[D][voice_assistant:223]: Starting Microphone
[D][ring_buffer:034]: Created ring buffer with size 16384
[D][voice_assistant:506]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[D][esp-idf:000]: I (90210) I2S: DMA Malloc info, datalen=blocksize=1024, dma_buf_count=4
[D][voice_assistant:506]: State changed from STARTING_MICROPHONE to START_PIPELINE
[D][voice_assistant:277]: Requesting start…
[D][voice_assistant:506]: State changed from START_PIPELINE to STARTING_PIPELINE
[D][voice_assistant:527]: Client started, streaming microphone
[D][voice_assistant:506]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[D][voice_assistant:512]: Desired state set to STREAMING_MICROPHONE
[D][voice_assistant:642]: Event Type: 1
[D][voice_assistant:645]: Assist Pipeline running
[D][voice_assistant:642]: Event Type: 3
[D][voice_assistant:656]: STT started
[D][light:059]: Red: 0%, Green: 0%, Blue: 100%
[D][light:109]: Effect: ‘Slow Pulse’
[D][voice_assistant:642]: Event Type: 11
[D][voice_assistant:805]: Starting STT by VAD
[D][voice_assistant:642]: Event Type: 12
[D][voice_assistant:809]: STT by VAD end
[D][voice_assistant:506]: State changed from STREAMING_MICROPHONE to STOP_MICROPHONE
[D][voice_assistant:512]: Desired state set to AWAITING_RESPONSE
[D][voice_assistant:506]: State changed from STOP_MICROPHONE to STOPPING_MICROPHONE
[D][light:109]: Effect: ‘Fast Pulse’
[D][esp-idf:000]: I (94633) I2S: DMA queue destroyed
[D][voice_assistant:506]: State changed from STOPPING_MICROPHONE to AWAITING_RESPONSE
[D][esp32.preferences:143]: Saving 1 preferences to flash: 1 cached, 0 written, 0 failed
[D][voice_assistant:642]: Event Type: 4
[D][voice_assistant:670]: Speech recognised as: " Turn off basement lights"
[D][voice_assistant:642]: Event Type: 5
[D][voice_assistant:675]: Intent started
[D][voice_assistant:642]: Event Type: 6
[D][voice_assistant:642]: Event Type: 7
[D][voice_assistant:698]: Response: “Turned off the light”
[D][light:051]: Brightness: 100%
[D][light:109]: Effect: ‘None’
[D][voice_assistant:642]: Event Type: 8
[D][voice_assistant:720]: Response URL: “https://mana-illu.duckdns.org/api/tts_proxy/lxB5LH-wqB87AiKAm-b2_Q.wav”
[D][voice_assistant:506]: State changed from AWAITING_RESPONSE to STREAMING_RESPONSE
[D][voice_assistant:512]: Desired state set to STREAMING_RESPONSE
[D][media_player:073]: ‘M5Stack Atom Echo a13ffc’ - Setting
[D][media_player:080]: Media URL: https://mana-illu.duckdns.org/api/tts_proxy/lxB5LH-wqB87AiKAm-b2_Q.wav
[D][media_player:086]: Announcement: yes
[D][speaker_media_player:420]: State changed to ANNOUNCING
[D][voice_assistant:642]: Event Type: 2
[D][voice_assistant:736]: Assist Pipeline ended
