When I send brightness_pct in a script or automation to a localTuya connected wi-fi light, it’s hit or miss whether or not the brightness gets set correctly:
- type: turn_on
device_id: cc917de81f53b486e99be8097b205210
entity_id: light.outside_perimeter_back
domain: light
brightness_pct: 25
I tried adding a delay between multiple turn_on commands since wi-fi is slower; but, it does not help.
The following does work:
- type: turn_on
domain: light
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 100
- type: turn_on
domain: light
brightness_pct: 30
But, I’m having to duplicate the turn_on command, giving it 100ms to first power on the light, then adjust the brightness.
Anyone else had this issue? Or, found (or can see) a more elegant way to do this?
