LocalTuya - Color Smart Bulb Automation Action
I have some smart bulbs that I want to use in an automation to control their Color and/or Color Temperature. With a bit of experimentation, I got their PIDs configured so that I can open the entity and all the manual controls work (On/Off & Brightness & White or Color Mode & RGBCW Color Selection & Color Temp).
However, the only Actions I can find for Automation are ON & OFF & Increase/Decrease Brightness. Although if I select ON, I can also set a brightness level.
How do I set the Color Temp within an Automation?
Also, in the case of a Smart Dimmer Switch, it would welcomed if I could set the Brightness level without having to incorporate it into an ON action. The reason for this is so I can preset the brightness level at certain times of day so that when the light is turned on manually, it starts out at the desired brightness. For example, say a light is set for 50% when it is shut off manually at 7PM. At mid-night, without turning the light ON, I want to set the brightness to 10% so that if the light is manually turned on in the middle of the night, it acts like a night light.
Thanks.
