"lock.open: door_lock" not working?
So I’m trying to use the new Lock component with my old K2000 RFID panel and a magnetic lock. I’ve got it working using this and I can lock and unlock it through home-assistant
output:
  - platform: gpio
    pin: 5
lock:
  - platform: output
    output: 'door_lock'
I’ve also connected the “Bell” outputs to gnd and to D4 on my wemos mini and it registers. So while I figure out how to get it to unlock when the right code is entered I tried using a “double click” action:
binary_sensor:
  - platform: gpio
    pin: 2
    filters:
      - invert:
    on_double_click:
      min_length: 50ms
      max_length: 350ms
      then:
        - lock.open: door_lock
But that gives me an error ID 'door_lock' of type gpio::GPIOBinaryOutput doesn't inherit from lock::lock. Please double check your ID is pointing to the correct value
I checked All actions list but there doesn’t seem to be any for locks or maybe it’s just not updated yet?
I tried using the Lambda examples from the lock page and ended up with this:
      then:
        - lambda: |-
            // Within lambda, get the lock state and conditionally do something
            if (id(door_lock).state == LOCK_STATE_LOCKED) {
              // Lock is LOCKED, do something here
              id(door_lock).unlock();
But when compiling that I get the following error
/config/esphome/front-door.yaml: In lambda function:
/config/esphome/front-door.yaml:52:22: error: 'class esphome::gpio::GPIOBinaryOutput' has no member named 'state'
   52 |             if (id(door_lock).state == LOCK_STATE_LOCKED) {
/config/esphome/front-door.yaml:54:20: error: 'class esphome::gpio::GPIOBinaryOutput' has no member named 'unlock'
   54 |               id(door_lock).unlock();
*** [/data/front-door/.pioenvs/front-door/src/main.cpp.o] Error 1
========================= [FAILED] Took 27.11 seconds =========================
Here are som pics :smiley: I think the rx/tx might be a wiegand interface but havn’t even started on that yet!
