Lock/Unlock August Lock with Z-Wave
I’m using an August SmartLock Pro. I have it added as a Z-Wave device and I have the august integration enabled. I’m able to fully control (lock/unlock) the lock using the integration but this relies on the August WiFi bridge. Ideally, I’d like to cut out the bridge and control the lock exclusively through Z-Wave, but so far commands sent to the Z-Wave device in HA don’t seem to do anything.
Is it possible to lock/unlock via Z-Wave? What configuration do I need to do this?
ozw logs:
2019-10-19 08:00:40.882 Info, Node004, Value::Set - COMMAND_CLASS_DOOR_LOCK - Locked - 0 - 1 - False
2019-10-19 08:00:40.882 Info, Node004, Value_Lock::Set - Requesting lock to be Unlocked
2019-10-19 08:00:40.882 Detail, Node004, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_DOOR_LOCK
2019-10-19 08:00:40.882 Detail, Node004, Queuing (Send) DoorLockCmd_Set (Node=4): 0x01, 0x0a, 0x00, 0x13, 0x04, 0x03, 0x62, 0x01, 0x00, 0x25, 0x67, 0xc0
2019-10-19 08:00:40.882 Detail, Node004, Queuing (Send) DoorLockCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x62, 0x02, 0x25, 0x68, 0xce
2019-10-19 08:00:40.882 Info, Node004, Processing (Send) Nonce Request message (Callback ID=0x67, Expected Reply=0x04)
2019-10-19 08:00:40.882 Info, Node004, Sending (Send) message (Callback ID=0x67, Expected Reply=0x04) - Nonce_Get(DoorLockCmd_Set) - 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x98, 0x40, 0x05, 0x02:
2019-10-19 08:00:40.889 Detail, Node004,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 08:00:40.889 Detail, Node004,   ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 08:00:42.125 Detail, Node004,   Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x7c, 0x95
2019-10-19 08:00:42.125 Detail, Node004,   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2019-10-19 08:00:42.125 Info, Node004, Request RTT 1243 Average Request RTT 1290
2019-10-19 08:00:42.146 Detail, Node004,   Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x04, 0x0a, 0x98, 0x80, 0x24, 0x0c, 0x8c, 0x44, 0x96, 0xd0, 0x9a, 0x66, 0xa7
2019-10-19 08:00:42.147 Info, Node004, Received SecurityCmd_NonceReport from node 4
2019-10-19 08:00:42.147 Info, Node004, Sending (Send) message (Callback ID=0x69, Expected Reply=0x04) - DoorLockCmd_Set (Node=4): 0x01, 0x0a, 0x00, 0x13, 0x04, 0x03, 0x62, 0x01, 0x00, 0x25, 0x69, 0xce
2019-10-19 08:00:42.157 Detail, Node004,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 08:00:42.157 Detail, Node004,   ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 08:00:42.183 Detail, Node004,   Received: 0x01, 0x07, 0x00, 0x13, 0x69, 0x00, 0x00, 0x03, 0x81
2019-10-19 08:00:42.183 Detail, Node004,   ZW_SEND_DATA Request with callback ID 0x69 received (expected 0x69)
2019-10-19 08:00:42.183 Info, Node004, Request RTT 1301 Average Request RTT 1295
2019-10-19 08:00:42.183 Detail,   Expected callbackId was received
2019-10-19 08:00:50.882 Error, Node004, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-10-19 08:00:50.882 Detail, Node004, Removing current message
2019-10-19 08:00:50.882 Detail, Node004, Notification: Notification - TimeOut
2019-10-19 08:00:50.883 Detail,
2019-10-19 08:00:50.883 Info, Node004, Processing (Send) Nonce Request message (Callback ID=0x68, Expected Reply=0x04)
2019-10-19 08:00:50.883 Info, Node004, Sending (Send) message (Callback ID=0x68, Expected Reply=0x04) - Nonce_Get(DoorLockCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x98, 0x40, 0x05, 0x02:
2019-10-19 08:00:50.890 Detail, Node004,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 08:00:50.890 Detail, Node004,   ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 08:00:52.140 Detail, Node004,   Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x7e, 0x97
2019-10-19 08:00:52.140 Detail, Node004,   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2019-10-19 08:00:52.140 Info, Node004, Request RTT 1257 Average Request RTT 1276
2019-10-19 08:00:52.162 Detail, Node004,   Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x04, 0x0a, 0x98, 0x80, 0x8b, 0x41, 0xf4, 0x41, 0xba, 0x67, 0xe9, 0xf7, 0x41
2019-10-19 08:00:52.162 Info, Node004, Received SecurityCmd_NonceReport from node 4
2019-10-19 08:00:52.162 Info, Node004, Sending (Send) message (Callback ID=0x6a, Expected Reply=0x04) - DoorLockCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x62, 0x02, 0x25, 0x6a, 0xcc
2019-10-19 08:00:52.173 Detail, Node004,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 08:00:52.173 Detail, Node004,   ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 08:00:52.199 Detail, Node004,   Received: 0x01, 0x07, 0x00, 0x13, 0x6a, 0x00, 0x00, 0x03, 0x82
2019-10-19 08:00:52.199 Detail, Node004,   ZW_SEND_DATA Request with callback ID 0x6a received (expected 0x6a)
2019-10-19 08:00:52.199 Info, Node004, Request RTT 1316 Average Request RTT 1296
2019-10-19 08:00:52.199 Detail,   Expected callbackId was received
2019-10-19 08:00:52.224 Detail, Node004,   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x04, 0x02, 0x98, 0x40, 0x2d
2019-10-19 08:00:52.224 Info, Node004, Received SecurityCmd_NonceGet from node 4
2019-10-19 08:00:52.224 Info, NONCES: 0x55, 0xf5, 0x84, 0x22, 0xd9, 0xb0, 0x78, 0x06
2019-10-19 08:00:52.224 Info, NONCES: 0x17, 0x9d, 0x32, 0xe2, 0xf4, 0xd1, 0x19, 0x1e
2019-10-19 08:00:52.224 Info, NONCES: 0x15, 0x2f, 0x8e, 0xff, 0x6f, 0x14, 0x32, 0xe2
2019-10-19 08:00:52.224 Info, NONCES: 0x88, 0x9c, 0xc7, 0xde, 0x97, 0xa9, 0x43, 0xeb
2019-10-19 08:00:52.224 Info, NONCES: 0xba, 0xc3, 0x97, 0x29, 0xd8, 0xc9, 0x0c, 0x5f
2019-10-19 08:00:52.224 Info, NONCES: 0xc5, 0xc3, 0xb6, 0x48, 0x4e, 0xeb, 0xe0, 0x08
2019-10-19 08:00:52.224 Info, NONCES: 0x85, 0x40, 0xb6, 0x01, 0x54, 0x08, 0xa0, 0x19
2019-10-19 08:00:52.224 Info, NONCES: 0x87, 0x48, 0x34, 0x2e, 0xd7, 0xe0, 0x21, 0x5c
2019-10-19 08:00:52.224 Info, Node004, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x04, 0x0a, 0x98, 0x80, 0x87, 0x48, 0x34, 0x2e, 0xd7, 0xe0, 0x21, 0x5c, 0x05, 0x01, 0x70:
2019-10-19 08:00:52.232 Detail, Node004,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 08:00:52.232 Detail, Node004,   ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 08:00:52.255 Detail, Node004,   Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x03, 0xe9
2019-10-19 08:00:52.255 Detail, Node004,   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2019-10-19 08:00:52.255 Info, Node004, Request RTT 1372 Average Request RTT 1334
2019-10-19 08:00:52.285 Detail, Node004,   Received: 0x01, 0x21, 0x00, 0x04, 0x00, 0x04, 0x1b, 0x98, 0x81, 0xea, 0xeb, 0xc3, 0x1c, 0x0f, 0x03, 0xd2, 0x3d, 0x34, 0x55, 0x06, 0x09, 0x1b, 0xfc, 0xfa, 0x71, 0x87, 0x73, 0xad, 0x8b, 0xae, 0x3f, 0xd5, 0x9c, 0xc6, 0x2f
2019-10-19 08:00:52.285 Info, Raw: 0x98, 0x81, 0xea, 0xeb, 0xc3, 0x1c, 0x0f, 0x03, 0xd2, 0x3d, 0x34, 0x55, 0x06, 0x09, 0x1b, 0xfc, 0xfa, 0x71, 0x87, 0x73, 0xad, 0x8b, 0xae, 0x3f, 0xd5, 0x9c, 0xc6, 0x2f
2019-10-19 08:00:52.285 Detail, Node004, Decrypted Packet: 0x00, 0x62, 0x03, 0xff, 0x01, 0x01, 0xfe, 0xfe
2019-10-19 08:00:52.285 Info, Node004, Response RTT 1402 Average Response RTT 1329
2019-10-19 08:00:52.285 Info, Node004, Received DoorLock report: DoorLock is Secured
2019-10-19 08:00:52.285 Detail, Node004, Refreshed Value: old value=true, new value=true, type=bool
2019-10-19 08:00:52.285 Detail, Node004, Changes to this value are not verified
2019-10-19 08:00:52.285 Detail, Node004,   Expected reply and command class was received
2019-10-19 08:00:52.285 Detail, Node004,   Message transaction complete
2019-10-19 08:00:52.285 Detail, Node004, Removing current message
configuration.yaml:
 zwave:
 30         usb_path: /dev/serial/by-id/usb-0658_0200-if00
 31         network_key: "0x04, 0x5B, 0x55, 0xA1, 0x5F, 0xAC, 0x2B, 0xB7, 0x94,
    0x39, 0x30, 0x39, 0xB9, 0xE9, 0x31, 0x53"
options.xml
  3 <Options xmlns='http://code.google.com/p/open-zwave/'>
  4   <Option name="logging" value="true" />
  5   <Option name="Associate" value="true" />
  6   <Option name="NotifyTransactions" value="false" />
  7   <Option name="DriverMaxAttempts" value="5" />
  8   <Option name="SaveConfiguration" value="true" />
  9   <!-- <Option name="RetryTimeout" value="40000" /> -->
 10   <!-- If you are using any Security Devices, you MUST set a network Key -->
 11   <Option name="NetworkKey" value="0x04, 0x5B, 0x55, 0xA1, 0x5F, 0xAC, 0x2B,
     0xB7, 0x94, 0x39, 0x30, 0x39, 0xB9, 0xE9, 0x31, 0x53"/>
 12
 13   <!-- Some Devices have a big UserCode Table, that can mean startup times
 14   when refreshing Session Variables is very long (Especialy on Security
 15   Devices) This option will make the UserCode CC stop on the first
 16   "available" usercode slot rather than retrieve every one -->
 17   <Option name="RefreshAllUserCodes" value="false" />
 18   <Option name="ThreadTerminateTimeout" value="5000" />
 19 </Options>
install info:
arch x86_64
dev false
docker false
hassio false
os_name Linux
python_version 3.7.4
version 0.100.2
virtualenv true
Lovelace
mode auto-gen
Hi - were you able to figure this out? I’m trying to do the same thing.
Unfortunately no. In addition to this thread, there’s an open issue on github (https://github.com/home-assistant/home-assistant/issues/28076) that’s also largely been ignored.
I’ve tentatively tried removing and re-adding the lock, but without much luck so far.
