This is on one of the Ameridroid/ODROID XU4Q HA bundles. The initial onboarding (thanks to my over-sensitive trackpad double-clicking) got short-circuited, and there appears to be a user that got installed, but it’s not the info I entered. None of the info in the “I’m Locked Out” post seems to apply to my situation. I can go in with a file viewer and see the configuration.yaml file (which is not located where that post says it should be, as there is no config or .config directory I can find. Did the file/directory structure change with HAOSS 10?), and it’s almost empty with nothing about a user or authentication in it.
If I just delete that file and reboot the XU4, will I get a fresh onboard?
