Locked out of RPI after update
Hey Guys,
I tried to update the home assistant software at the beginning of this year but the RPI locked up. I have not had time to look into it until now. What is my best option going forward? Has my config been lost?
did you see if the device is connecting to your network?
It is not connecting to the network
Did you setup static ip for the device? if not there is a chance that the ip could have changed and you are accessing a different ip. If this is not the case, then mostly it would be corruption of sd card. If the sd card is corrupted you would need to make a fresh installation on a formatted sd card. I would also recommend going for a HDD or SDD install so that corruptions can be avoided.
