Log bash command data as value in HA
As webscraping using scrape is not working properly with an Ginlong Solis internal webinterface I’m trying to find an alternative.
After some invensitgation I managed to run this command from the shell
curl -s http://user:pass@ip/status.html | grep ‘var webdata_now_p’
The output is:
var webdata_now_p = “70”;
Ofcourse I’m interested in the value 70.
Now I want to schedure this command and store the value 70 every 5 minutes.
But how to proceed?
I have also tried node-red to achieve this but I’m stuck there as well. I used the same command in an exec node but it throws an error (error 7). However the content of the html is displayed in the debug screen. Only how to extract the proper value as the HTML class selector will probable hit the same issue as scrape. (The classes refer to variables, not the values itself, something with javascript?)
For reference: This is the enitre HTML retrieved, including the desried values. (in de var section, for example webdata_now_p)
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<!-- saved from url=(0031)http://192.168.2.15/status.html -->
<html xmlns="http://www.w3.org/1999/xhtml"><head><meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<style type="text/css">
.in_body
	margin-top:0px;
	margin-left:0px;
	margin-right:0px;
	margin-bottom:0px;
	background-color:transparent;
.div_c
	margin-left:50px;
	margin-right:50px;
	margin-top:50px;
	margin-bottom:50px;
.cu
	cursor:pointer;
.b
	font-weight:bold;
.lab_5
	font-size:16px;
	color:#666666;
	margin-left:-20px;
.lab_l2
	float:left;
	width:32%;
	color:#666666;
	margin-bottom:-2px;
	font-size:14px;
.lab_r2
	float:left;
	width:68%;
	color:#666666;
	text-align:right;
	font-size:14px;
.cl
	clear:left;
.line
	height:1px;
	background-color:#666666;
	width:100%;
	margin-top:5px;
	margin-bottom:5px;
.sp_5
	height:5px;
	width:500px;
.sp_20
	height:20px;
	width:500px;
.label
	float:left;
	width:50%;
	color:#666666;
	margin-bottom:-2px;
	font-size:14px;
.lab_r
	float:left;
	width:50%;
	color:#666666;
	text-align:right;
	font-size:14px;
.lab_l
	float:left;
	width:40%;
	color:#666666;
	margin-bottom:-2px;
	margin-left:10%;
	font-size:14px;
.line_l
	height:1px;
	width:450px;
	margin-top:5px;
	margin-bottom:5px;
	margin-left:50px;
.sub
    display:inline-block;
    width:16px;
    text-align:center;
</style>
<script type="text/javascript">
var height=0;function fileText(id,value){if(document.getElementById(id)){document.getElementById(id).innerHTML=value}}function changeFont(){reCon("main_div").style.fontFamily=window.parent.reFont()}function child_getH(){var nh=document.body.offsetHeight+100;if(nh<500||nh==null){nh=500}if(height!=nh){height=nh;window.parent.child_height(height)}}function reCon(id){return document.getElementById(id)}function ready(){try{window.parent.show_ifr()}catch(e){}child_getH()}function show(v){var c=document.getElementById(v);if(c!=null){c.style.display=""}}function hide(v){var c=document.getElementById(v);if(c!=null){c.style.display="none"}};
</script>
var webdata_sn = "123456789 ";
var webdata_msvn = "000C";
var webdata_ssvn = "001E";
var webdata_pv_type = "0078";
var webdata_rate_p = "";
var webdata_now_p = "1420";
var webdata_today_e = "24.60";
var webdata_total_e = "2290.0";
var webdata_alarm = "";
var webdata_utime = "0";
var cover_mid = "123456789";
var cover_ver = "MW_08_0501_1.57";
var cover_wmode = "STA";
var cover_ap_ssid = "AP_123456789";
var cover_ap_ip = "10.10.10.10";
var cover_ap_mac = "123456789";
var cover_sta_ssid = "123456789";
var cover_sta_rssi = "100%";
var cover_sta_ip = "10.10.10.10";
var cover_sta_mac = "123456789";
var status_a = "1";
var status_b = "0";
var status_c = "0";
function initPageText(){var list=window.parent.reList("status");fileText("st1",list["t1"]);fileText("st2",list["t2"]);fileText("st3",list["t3"]);for(var i=1;i<=27;i++){if(i!=14){fileText("tx"+i,list[i])}}changeFont();child_getH()}function upfold(v){if(document.getElementById("up_"+v+"_div").style.display=="none"){show("up_"+v+"_div");reCon("p_"+v).innerHTML="-"}else{hide("up_"+v+"_div");reCon("p_"+v).innerHTML="+"}}function init_main_page(){var on=window.parent.reTip("1");var off=window.parent.reTip("2");document.getElementById("cover_mid").innerHTML=cover_mid;document.getElementById("cover_ver").innerHTML=cover_ver;document.getElementById("cover_ap_status").innerHTML=off;document.getElementById("cover_sta_status").innerHTML=off;if(cover_wmode!="STA"){document.getElementById("cover_ap_status").innerHTML=on;document.getElementById("cover_ap_ssid").innerHTML=cover_ap_ssid;document.getElementById("cover_ap_ip").innerHTML=cover_ap_ip;document.getElementById("cover_ap_mac").innerHTML=cover_ap_mac}if(cover_wmode!="AP"){document.getElementById("cover_sta_status").innerHTML=on;document.getElementById("cover_sta_ssid").innerHTML=cover_sta_ssid;document.getElementById("cover_sta_rssi").innerHTML=cover_sta_rssi;document.getElementById("cover_sta_ip").innerHTML=cover_sta_ip;document.getElementById("cover_sta_mac").innerHTML=cover_sta_mac}if(webdata_sn==""){webdata_sn="---"}fileText("webdata_sn",webdata_sn);if(webdata_msvn==""){webdata_msvn="---"}fileText("webdata_msvn",webdata_msvn);if(webdata_ssvn==""){webdata_ssvn="---"}fileText("webdata_ssvn",webdata_ssvn);if(webdata_pv_type==""){webdata_pv_type="---"}fileText("webdata_pv_type",webdata_pv_type);if(webdata_rate_p==""){webdata_rate_p="---"}fileText("webdata_rate_p",webdata_rate_p+" W");if(webdata_now_p==""||webdata_now_p==0){webdata_now_p="---"}fileText("webdata_now_p",webdata_now_p+" W");if(webdata_today_e==""){webdata_today_e="---"}fileText("webdata_today_e",webdata_today_e+" kWh");if(webdata_total_e==""){webdata_total_e="---"}fileText("webdata_total_e",webdata_total_e+" kWh");if(webdata_alarm==""){webdata_alarm="---"}fileText("webdata_alarm",webdata_alarm);if(webdata_utime==""){if(document.getElementById("webdata_sn").innerHTML=="---"){webdata_utime="---"}else{webdata_utime=value+window.parent.reTip("5")}}fileText("webdata_utime",webdata_utime);var st_en=window.parent.reTip("3");var st_dis=window.parent.reTip("4");var st_un=window.parent.reTip("41");if(status_a=="1"){document.getElementById("cover_remote_status_a").innerHTML=st_en}else{if(status_a=="0"){document.getElementById("cover_remote_status_a").innerHTML=st_dis}else{document.getElementById("cover_remote_status_a").innerHTML=st_un}}if(status_b=="1"){document.getElementById("cover_remote_status_b").innerHTML=st_en}else{if(status_b=="0"){document.getElementById("cover_remote_status_b").innerHTML=st_dis}else{document.getElementById("cover_remote_status_b").innerHTML=st_un}}};
</script>
</head>
<body class="in_body" onload="init_main_page();">
	<div class="div_c" id="main_div">
        <div class="lab_5 cu b" onclick="upfold(1);child_getH();"><span class="sub" id="p_1">-</span><span id="st1" style="margin-left:3px"></span></div>
        <div class="sp_5"></div>
        <div id="up_1_div">
        <div class="lab_l2" id="tx1"></div>
                <div class="lab_r2" id="webdata_sn"></div>
        <div class="cl"></div>
        <div class="line"></div>
        <div class="lab_l2" id="tx2"></div>
                <div class="lab_r2" id="webdata_msvn"></div>
        <div class="lab_l2" id="tx3"></div>
                <div class="lab_r2" id="webdata_ssvn"></div>
        <div class="lab_l2" id="tx4"></div>
                <div class="lab_r2" id="webdata_pv_type"></div>
        <div class="lab_l2" id="tx5"></div>
                <div class="lab_r2" id="webdata_rate_p"></div>
        <div class="lab_l2" style="color:#666666;font-weight:bold;" id="tx6"></div>
                <div class="lab_r2" id="webdata_now_p" style="color:#666666;font-weight:bold;"></div>
        <div class="lab_l2" style="color:#666666;font-weight:bold;" id="tx7"></div>
                <div class="lab_r2" id="webdata_today_e" style="color:#666666;font-weight:bold;"></div>
        <div class="lab_l2" style="color:#666666;font-weight:bold;" id="tx8"></div>
                <div class="lab_r2" id="webdata_total_e" style="color:#666666;font-weight:bold;"></div>
        <div class="lab_l2" style="color:#666666;font-weight:bold;" id="tx9"></div>
                <div class="lab_r2" id="webdata_alarm" style="color:#666666;font-weight:bold;"></div>
        <div class="lab_l2" style="color:#666666;font-weight:bold;" id="tx10"></div>
                <div class="lab_r2" id="webdata_utime" style="color:#666666;font-weight:bold;"></div>
        </div>
        <div class="sp_20"></div>
        <div class="lab_5 cu b" onclick="upfold(2);child_getH();"><span class="sub" id="p_2">+</span><span id="st2" style="margin-left:3px"></span></div>
                <div id="up_2_div" style="display:none">
                <div class="label" id="tx11"></div>
                <div class="lab_r" id="cover_mid"></div>
                <div class="label" id="tx12"></div>
                <div class="lab_r" id="cover_ver"></div>
                <div class="label" id="tx13"></div>
                <div class="lab_r" id="cover_ap_status" style="color:#666666;font-weight:bold;"></div>
                <div class="lab_l" id="ap_ssid">SSID</div>
                <div class="lab_r" id="cover_ap_ssid"></div>
                <div class="line_l"></div>
                <div class="lab_l" id="tx15"></div>
                <div class="lab_r" id="cover_ap_ip"></div>
                <div class="lab_l" id="tx16"></div>
                <div class="lab_r" id="cover_ap_mac"></div>
                <div class="label" id="tx17"></div>
                <div class="lab_r" id="cover_sta_status" style="color:#666666;font-weight:bold;"></div>
                <div class="lab_l" id="tx18"></div>
                <div class="lab_r" id="cover_sta_ssid"></div>
                <div class="lab_l" id="tx19"></div>
                <div class="lab_r" id="cover_sta_rssi"></div>
                <div class="lab_l" id="tx20"></div>
                <div class="lab_r" id="cover_sta_ip"></div>
                <div class="lab_l" id="tx21"></div>
                <div class="lab_r" id="cover_sta_mac"></div>
                </div>
                <div class="lab_5 cu b" onclick="upfold(3);child_getH();"><span class="sub" id="p_3">+</span><span id="st3" style="margin-left:3px"></span></div>
                <div id="up_3_div" style="display:none">
                <div class="label" id="tx25"></div>
                <div class="lab_r" id="cover_remote_status_a"></div>
                <div class="label" id="tx26"></div>
                <div class="lab_r" id="cover_remote_status_b"></div>
                </div>
    </div>
	    initPageText();
	    ready();
	</script>
</body></html>
