Logger: homeassistant.components.websocket_api.http.connection
Zdroj: components/websocket_api/http.py:533
Integrácia: Home Assistant WebSocket API (dokumentácia, problémy)
Prvýkrát sa vyskytol: 18:24:45 (3 výskytov)
Naposledy prihlásený: 18:25:04
Hello
in /homeassistant/configuration.yaml I have inserted
http:
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
- ::1
and in security Long-lived access tokens I have generated the iOS Home Assistant App token
in the logs I still have the error … Thanks for the advice
[281471951793040] from 127.0.0.1 (Home Assistant/2025.1 (io.robbie.HomeAssistant; build:2025.1073; iOS 18.3.1)): Disconnected: Received close message during auth phase
[281471951796496] from 127.0.0.1 (Home Assistant/2025.1 (io.robbie.HomeAssistant; build:2025.1073; iOS 18.3.1)): Disconnected: Received close message during auth phase
[281472849105904] from 127.0.0.1 (Home Assistant/2025.1 (io.robbie.HomeAssistant; build:2025.1073; iOS 18.3.1)): Disconnected: Received close message during auth phase
