Log Template Error
In the logs, I get this error all the time. What is it?
Registrador: homeassistant.helpers.template
Fuente: helpers/template.py:2769
Ocurrió por primera vez: 18:24:11 (1 ocurrencias)
Última vez registrado: 18:24:11
Template variable error: builtin_function_or_method object has no element 0 when rendering '{{ (value_json["items"][0].id.videoId | string) }}'
I’m assuming that the code between the {{ and }} in the error message doesn’t look familiar to you and isn’t yours. If so, this must be coming from some integration. The only suggestion I can make, without additional information, is to disable one integration at a time to see if that makes the error go away. Since the error message seems to pertain to video, I’d focus on video-related integrations.
You can also configure the logger to suppress certain error messages, if you’re sure that this message is benign and not an indicator of a problem.
With some luck, another reader of the forum might have encountered this specific error message and will be able to provide a more specific suggestion.
