My log viewer UI from the toolbar says it is not running nand I am uunable to start it. The addon log is showing:
Error [ERR_UNHANDLED_ERROR]: Unhandled error. ("watch for /homeassistant/home-assistant.log failed: Error: ENOENT: no such file or directory, stat '/homeassistant/home-assistant.log'")
Also I have one command line sensor that also relies upon the same file which will not update, presumable because the file is missing or corrupted, any ideas?
I am researching it and read somewhere that: “There is a custom integration to replace it” do you know where the documentation for same might be? I also need to figure out how to replace the command line sensor
