I just found that all the logbook history before Mar 8 is removed.
Is it pruned regularly? If yes, how to disable or extend that?
Thanks!
Recorder - Home Assistant (home-assistant.io)
And you should not change that as it will make the whole thing go slower over timeā¦I know some have been able to go to 30+ days but the question remains: why !
If you require longer term data then try to work with statistics instead or export to Influxdb
Thanks a lot!
