Logger not logging
Running on a Pi, installed from image. I can’t get anything to log at all. I have updated my configuration.yaml:
Our command line:
$ ha help
➜  ~ cd config
➜  config pwd
/root/config
➜  config cat configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Example configuration.yaml entry
logger:
  default: debug
➜  config ls /var/log -la
total 8
drwxr-xr-x    2 root     root          4096 Oct 21 05:25 .
drwxr-xr-x    1 root     root          4096 Nov 24 05:46 ..
➜  config
As you can see, not a single log file exists in var/log. I have the logger setting enabled, so I am puzzled. Any ideas?
Why are you looking in /var/log?
The homeassistant log is in your config directory, same place it’s always been.
OK, so I was looking in var/log b/c that’s where it is on every other *nix platform I’ve ever used. No worries. I do see the home-assistant.log file.
But I have another problem then. I installed the log viewer add-on and it is blank. No logs at all. I have started the add-on, and no errors reported in the log page for the log viewer add-on. But the log viewer page does not show any logs at all. I suppose that is a different question from the original, but I wonder if it has an easy answer?
I have no idea about the log viewer addon, but you can view your homeassistant logs in the interface under configuration > logs, or in supervisor > system > log provider
