I used to get these, too. I should’ve been more diligent in tracking the source down using a service like WireShark. However, I eventually switched to using Nginx Proxy Manager and using wildcard domains and they went away.
What device resides at IP Address 192.168.0.148?
Your router should be able to tell you. Even a MAC Address may be of assistance to track down the culprit.
Where are you seeing this message?
I don’t know why this is happening. It displays the HA dashboard just like my other three View Assist satellites. I THINK it may suffer from WIFI connectivity issues or something that the others don’t.
The main question I am asking is how do I squelch the notification. I am not going to go through a lot of config/reconfig of the device to fix this annoying popup as the device is working fine. I’m looking for an ‘ignore this IP’ or just turn off this login attempt failed altogether.
And which Integration in HA Does this Android Device Connect to ???
PS: Im pretty sure if you check the “Detailed RAW Log” you will get a “hint” type
A Warning from http.ban
