I just installed the Nginx Proxy Manager add-on and configured everything. I also successfully retrieved an SSL certificate by Let’s Encrypt.
When I’m now trying to access my HA frontend (on a PC), my login fails with a notification on my other devices, that a Login attempt failed (I’m in an VPN with that iPhone):
My entered username and password are correct. The problem occurs after entering my OTP (2FA with Google Authenticator); “Neu anfangen” means “Start again”:
My configuration is as follows: Router
Forwarding
Port 80 ext to 80 int
Port 443 ext to 443 int
Hi, your config looks ok; only difference vs. my setup is that I use /23 for the trusted proxies and I do not have totp in my yaml config. I do have it enabled but through the gui.
As a first step, can you still login locally with the PC, eg. by approaching http://ha_ip:8123? Also, a second step, turn off 2FA temporarily (or make a new account without it) and check if that allows you to log in.
At least now you know it’s not an issue with your NGINX setup. I am not aware of any 2FA bugs but then again, never experienced issues so never bothered to look.
Did you also try to login with your original account on another device or different browser/incognito mode? If this works then it’s not a 2FA issue but probably browser related and you could try to purge your cookies/browser history (and delete your tokens within HA).
I just did (HA app → user account → deleting all tokens). No success. Very weird: I still can’t login with my user account (same message: “Start again”)?! So it’s not a 2FA-related problem.
Okay. That’s a bit embarassing… I just saw that I obviously someday enabled the option: “Only allow login from local network” in the user settings (Configuration → Users → User Account).
