I’ve successfully logged in and out using UI, but trying to log in from the terminal command prompt, I’m getting Login incorrect error message. I also trired using Windows explorer to connect to HA server, I get user name and password promopt, enter same credentials, but it also rejects them.
Any ideas where else I can diagnose the problem?
I did change password and logged out, then back in to ensure that wasn’t the problem
I did create another user with admin credits and that didn’t work
Thanks for the quick reply. Root without password worked!
I have Samba enabled and is running. I ran the Windows command to connect to IP of Home Assistant. I got challenged for user name and password which I entered, but access was denied. Are there other better methods as trying to transfer HACS to HA directory?
