Second that. Great work Homeassistant, some of the other HA communities out there are still wondering what is going on!
Someone on the home assistant team should get in contact with the register (https://www.theregister.co.uk) - Iām sure theyād be interested in a story like thisā¦ It would help pile the pressure on Logitech to give a proper solution.
They are developer friendly and their product has stunning build quality. I own three. But it is still an evolving product and their software updates are months and months delayed with long gaps between releases.
I also feel it needs just a few more hard buttons as it does not offer pick it up and action usage.
Both Homey and openHAB have really competent support for Neeo. Hereās hoping for something equally viable here.
I think you are right, we are fairly safe for now. The title of this blog actually misrepresents the situation. The local API was not really removed, it was replaced with a more modern version (websocket). The new interface works at least as well. We were just caught by surprise because Logitech does not announce changes to this unofficial interface.
I donāt see Logitech removing the local connection, waiting several seconds for the volume to change via the cloud would be unacceptable. They might try to protect it with encryption etc. but nothing of that is present in the current websocket interface and it would take quite a while to roll out.
I dont think the cloud APIs donāt expose the same capabilities. You know how limited the Google Home and Alexa integrations are? Thatās because of the Cloud API they are using.
Good point, I think theyāll need a local API in one form or another indefinitely. Hereās hoping it lasts, at least until NEEO is up-to-snuff in HA
Great article about it:
Nice to see a sensible, sticking to the real facts post rather than all this anti Logitech garbage others seem intent on spouting.
I have just upgraded to the latest HA hot fix release, but both of my Harmony hugs still not workingā¦ They both are upgraded to latest firmware.
Is there anything else I need to do in the configuration file to make it work?
Thank you guys so much for quick fix! Just need some docs on how to make it work again.
Same, I updated to 0.84.4 but get this in the logs
2018-12-20 13:22:47 ERROR (MainThread) [homeassistant.components.remote] Error while setting up platform harmony
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/remote/harmony.py", line 106, in async_setup_platform
name, address, port, activity, harmony_conf_file, delay_secs)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/remote/harmony.py", line 155, in __init__
self._client = harmony_client.HarmonyClient(host)
TypeError: __init__() takes 1 positional argument but 2 were given
I get the same thing in my logs as well, and just the usual yellow banners in Lovelace where the hub commands should be.
You guys using docker? Seems a hotfix 84.5 out
I got 0.84.5 hass.io with my generic Linux install on a NUC 10 or so hours agoā¦ I wonder what the delay is for the Pi?
Have you tried updating via ssh?
Please file GitHub issues for the problems that you find with the updated integration.
Are you saying that this removal was actually announced at some point?
Anyone have a feel for when 0.84.4+ will be rolled out onto the Raspberry Pi versions for Hass.io? Reloading the supervisor or updating via SSH is still only getting 0.84.3, which is whatās reported for all architectures at https://s3.amazonaws.com/hassio-version/stable.json or the beta channel. Thanks
Did you try forcing 0.84.5?
hassio ha update -o version=0.84.5
The json file and version sensor only show 0.84.3 for me too but I manually updated via the above command line 10+ hours agoā¦
That fixed it. I was missing the -o flag.
I have forwarded this to the big german techsite heise.de this morning. 2hrs later there is an article
I really donāt get why big companies donāt embrace the communities that enrich their product.
